With pleasure.sgrogan wrote: ↑Wed May 09, 2018 8:46 pm @chrisb, can you add this to the wiki https://www.freecadweb.org/wiki/Sketcher_Polyline
Same here...I just cycle through, but I know what I am looking for, I've never memorized the order.
Done. Do you think it needs images to show what the words say?chrisb wrote: ↑Wed May 09, 2018 8:49 pmsgrogan wrote: ↑Wed May 09, 2018 8:46 pm @chrisb, can you add this to the wiki https://www.freecadweb.org/wiki/Sketcher_Polyline
Words look good to me.
The key is "M" the character is "m", IMO.chrisb wrote: ↑Wed May 09, 2018 9:42 pm There is one thing, that I'm not sure of, it might be a detail which I am unable to understand as a non native english speaker. It is always said in the wiki and in the forum as well, that you have to hit the M key. In fact it's the lower key, so should it rather be "the m key" or
would the capital version be noted as "Shift+M key"?
Looking at the keyboard you are perfectly right, and I'm glad I changed the wiki docs from the "letter M" to the "key M"
Community projects work only with community effort.
And thanks for adding this.
Yes - that is one valid solution to solve the Sketch, but it is not the one we want. It happens because there should be a Horizontal Constraint applied to that line segment. But, if you try to apply a Horizontal Constraint there, in the Sketcher Messages area you'll see that this is a Redundant Constraint and you are asked to delete it. Instead, delete the Equality Constraint #43. Because of all the other Constraints in the Sketch, this segment is forced to be equal in length to its twin segment on the other side.FC-Architecter wrote: ↑Wed May 09, 2018 5:37 pm Just tried to set the vertical distance between the x axis and the spokes at 25.4 mm, as the tutorial says. minute 6:50
But it came out with the vertical spokes much too elongated as you can see in the file.
Yes, I went through them.chrisb wrote: ↑Wed May 09, 2018 8:48 pm I have revisited the tutorial and I still fully agree with a previous post of mine stating that these tutorials are among the best and most detailed FreeCAD tutorials I know. It is almost unbelievable that you have so many problems with them.
Did you work through the other tutorials before?
I deleted Equality Constraint 43.bejant wrote: ↑Thu May 10, 2018 12:56 pm ....
Yes - that is one valid solution to solve the Sketch, but it is not the one we want. It happens because there should be a Horizontal Constraint applied to that line segment. But, if you try to apply a Horizontal Constraint there, in the Sketcher Messages area you'll see that this is a Redundant Constraint and you are asked to delete it. Instead, delete the Equality Constraint #43. ....
Now you can apply the last Distance Constraint by selecting the right endpoints of the horizontal line segments (just as you had tried to do before) to set the vertical distance of the inside of the pulley cheeks.
Notice that instead of doing any of the things I mentioned above, you can instead open Sketch in that last model you posted, select the vertical line segment, and apply the Vertical Distance Constraint to solve the last Degree Of Freedom and thereby Fully Constrain the Sketch.
Another option is to instead select the left endpoints of the horizontal line segments and apply the Vertical Distance Constraint.
