Addons_installer stop working
SebastianKulik
Postby SebastianKulik » Tue May 01, 2018 9:58 pm
afterreinstall Win10 x64 (just clean re-install) and switching to new 0.17 the addons_installer hangs on on trying to install any of Workbenches (need actually assembly2).
Downloaded assembly2 manually and copied into "C:\Program Files\FreeCAD 0.17\Mod" (copy to "...users\appdata\roaming\FreeCAD\Macro\Mod" not worked) can use assembly, but try to open KiCAD generated STEP get error about "A part can be imoirted from a FreeCAD document with exactly one visible part. Aborting operation".
Try to convert the STEP file to one solid in 0.17 is failed every time (tried in different ways as well), converting in 0.16 was fine (USB connector model nedded to be modified, but it works as well). Use assembly2 in 0.16 was fine to combine two PCB boards as well, in 0.17 a little bit crappy.....
Any help, guys?
Best regards from Germany,
Sebastian
Re: Addons_installer stop working
Postby chrisb » Tue May 01, 2018 11:24 pm
Do you have any fancy characters like german umlauts in your user name? Which version do you use exactly?
russ_arnold
Postby russ_arnold » Wed May 02, 2018 3:20 am
Doesn't help you, but I'm having exactly the same problem with the addons installer. Just sits there forever trying to download the list of workbenches. It doesn't actually hang as I can switch to the macros tab, but that also tries to download the list of macros forever. I do have a space in my Windows account name which may be significant, or not.
jmaustpc
Postby jmaustpc » Wed May 02, 2018 4:07 am
please post your FreeCAD version data in the manner explained in the "forum rules" link above.
HarryGeier
Postby HarryGeier » Wed May 02, 2018 5:40 am
here it happens with :
Version: 0.18.13701 (Git)
Branch: (HEAD detached at FETCH_HEAD)
Hash: 131f6a6506aa2b1d59c445f8e8354b12c63ff47f
Python version: 2.7.8
OCC version: 7.0.0
<asm3.main> 1.834 - init_gui.py(11): failed to import sympy: No module named sympy
File "C:\FreeCAD-asm3\Mod\AddonManager\AddonManager.py", line 415, in run
u = urllib2.urlopen("https://github.com/FreeCAD/FreeCAD-addons")
File "C:\FreeCAD-asm3\bin\lib\urllib2.py", line 127, in urlopen
return _opener.open(url, data, timeout)
File "C:\FreeCAD-asm3\bin\lib\urllib2.py", line 404, in open
response = self._open(req, data)
File "C:\FreeCAD-asm3\bin\lib\urllib2.py", line 427, in _open
'unknown_open', req)
File "C:\FreeCAD-asm3\bin\lib\urllib2.py", line 382, in _call_chain
result = func(*args)
File "C:\FreeCAD-asm3\bin\lib\urllib2.py", line 1247, in unknown_open
raise URLError('unknown url type: %s' % type)
urllib2.URLError: <urlopen error unknown url type: https>
0.17 release version is okay, but i am sure at home i had the same issue yesterday with latest 0.17 version
Kaum macht man´s richtig , gehts´s
My Video Tutorials on Youtube: https://www.youtube.com/channel/UCoe3B ... p8Q/videos
My FreeCAD Stuff on Hidrive: https://my.hidrive.com/share/qr3l1yddy6#$/
easyw-fc
Postby easyw-fc » Wed May 02, 2018 5:46 am
OCC version: 7.0.0
This is Assembly 3 release build, not any of the official build.
russ_arnold
Postby russ_arnold » Wed May 02, 2018 7:11 am
Here is the version info
Version: 0.17.13519 (Git)
Branch: releases/FreeCAD-0-17
Hash: 1a8b868018f45ea486c0023fdbfeb06febc1fb89
Python version: 2.7.14
OCC version: 7.2.0
Postby chrisb » Wed May 02, 2018 7:34 am
No problem here:
OS: Mac OS X
Branch: (HEAD detached at 1a8b868)
Qt version: 5.10.1
OCC version: 7.2.0
Postby chrisb » Wed May 02, 2018 7:36 am
No problem here either,must be an issue specific to the Windows version.
OS: Ubuntu 16.04.4 LTS
Version: 0.18.13648 (Git)
Build type: None
Hash: 717a4a50a2a2b9ef483effed0210e70011dea5c9
Python version: 2.7.12
OCC version: 7.2.0
sgrogan
Postby sgrogan » Wed May 02, 2018 2:02 pm
Works for me, no problems. I am using the portable version (ie no installer)
OS: Windows 7
OCC version: 7.2.0
