Addons_installer stop working
GeneFC
Re: Addons_installer stop working
Postby GeneFC » Wed May 02, 2018 2:14 pm
No problem for me on Windows 7 and FC version 0.17 release. May be some sort of internet access permission issue.
OS: Windows 7
Version: 0.17.13519 (Git)
Branch: releases/FreeCAD-0-17
Python version: 2.7.14
OCC version: 7.2.0
Gene
Postby chrisb » Wed May 02, 2018 2:20 pm
Or it is again time for deleting the config files.
HarryGeier
Postby HarryGeier » Wed May 02, 2018 8:35 pm
here, at home, it works now too...
OS: Windows 7
Version: 0.18.13554 (Git)
Hash: 6ac274b081736ea8867b4856d3bda9a210b83876
Python version: 3.6.4
Qt version: 5.6.2
OCC version: 7.2.0
seems it was a temporary effect..
easyw-fc
Postby easyw-fc » Wed May 02, 2018 9:24 pm
SebastianKulik wrote:
Tue May 01, 2018 9:58 pm
Downloaded assembly2 manually and copied into "C:\Program Files\FreeCAD 0.17\Mod" (copy to "...users\appdata\roaming\FreeCAD\Macro\Mod" not worked) can use assembly, but try to open KiCAD generated STEP get error about "A part can be imoirted from a FreeCAD document with exactly one visible part. Aborting operation".
Try to convert the STEP file to one solid in 0.17 is failed every time (tried in different ways as well), converting in 0.16 was fine (USB connector model nedded to be modified, but it works as well). Use assembly2 in 0.16 was fine to combine two PCB boards as well, in 0.17 a little bit crappy.....
Any help, guys?
Best regards from Germany,
Sebastian
for this issue could you please open a new thread?
apeltauer
Postby apeltauer » Tue Jan 22, 2019 2:01 pm
HarryGeier wrote:
Wed May 02, 2018 5:40 am
<asm3.main> 1.834 - init_gui.py(11): failed to import sympy: No module named sympy
File "C:\FreeCAD-asm3\Mod\AddonManager\AddonManager.py", line 415, in run
u = urllib2.urlopen("https://github.com/FreeCAD/FreeCAD-addons")
File "C:\FreeCAD-asm3\bin\lib\urllib2.py", line 127, in urlopen
return _opener.open(url, data, timeout)
File "C:\FreeCAD-asm3\bin\lib\urllib2.py", line 404, in open
response = self._open(req, data)
File "C:\FreeCAD-asm3\bin\lib\urllib2.py", line 427, in _open
'unknown_open', req)
File "C:\FreeCAD-asm3\bin\lib\urllib2.py", line 382, in _call_chain
result = func(*args)
File "C:\FreeCAD-asm3\bin\lib\urllib2.py", line 1247, in unknown_open
raise URLError('unknown url type: %s' % type)
urllib2.URLError: <urlopen error unknown url type: https>
Hi all,
i have exactly the same error with the addon manager. Does someone can help or has an idea?
I already have deleted the config files but it does not help :(
Version: 0.18.16818 (Git)
Branch: (HEAD detached at d2e22bcfa)
Hash: d2e22bcfaf298a1f686e2364d272caa882032202
Python version: 2.7.8
OCC version: 7.0.0
apeltauer
Postby apeltauer » Thu Jan 24, 2019 9:15 am
After some debugging i found the solution for me.
Simply easy....
In my installation the following files were missing:
ssleay32.dll
libeay32.dll
After adding them everything works as expected....
