Asymmetric tapered hole
earthcare
Postby earthcare » Wed May 16, 2018 6:36 am
Hi
I have a real challenge: I cam't even work out where to start.
I have a flat surface which is at 45 degrees to the Y and X axes. In that surface I need to form a tapered hole, but one that it not circular. A 2D drawing of the hole is attached.
I presume I can create the item, and position/align it to the existing drawing, then subtract one from the other, but:
  • I have absolutely no idea how to draw this item!
  • I have never positioned something that is at 45 degrees to one the standard axes.
I could probably work out the second (eventually) but the first baffles me completely.
Can anyone help?
Screenshot from 2018-05-16 16-27-50.png (1.26 KiB) Viewed 499 times
microelly2
Re: Asymmetric tapered hole
Postby microelly2 » Wed May 16, 2018 7:23 am
for your parts you have a placement property.
you can change the direction by the rotation attribute
if you switch to euler angle representation of the rotation it is easy to rotate along the main axes.
meme2704
Postby meme2704 » Wed May 16, 2018 7:30 am
Do you vant something like that?
lanticulaire.FCStd
(47.63 KiB) Downloaded 17 times
HarryGeier
Postby HarryGeier » Wed May 16, 2018 1:10 pm
You can do that easilyy with a loft in Part Design WB
2018-05-16 15_09_26-FreeCAD.png (44.4 KiB) Viewed 465 times
If you want to sketch on slanted planes.. datum planes are the magic word
See in this video:
https://www.youtube.com/watch?v=dw9EDlYfE14&t=74s
earthcare
Postby earthcare » Wed May 16, 2018 9:54 pm
microelly2, thanks for the tip.
meme2704, that's almost it, thank you. The circle at the bottom of the hole is centred in the hole, rather than off-set, though, and the hole is perpendicular to a face that is at 45 degrees to the main axes of the drawing - sorry if I misled you in that regard.
HarryGeier, I'll have a look at datum planes, thanks.
