Section analysis view
geobruce
Postby geobruce » Sat May 19, 2018 9:41 am
Hi
I recently got the courage to move to freecad from fusion360, and from the moment I got the spreadsheet working for parametric modelling. I'm getting comfortable with it.
But there is one thing I can't find:
Section analysis view, when you want to see a cut view from your model real quick like in this video: https://youtu.be/htJWiWYxqk0?t=11s
I found you can split a body but this hadn't the desired result, also I found you could do it in the drawing bench.
But I want something you could use just as easy as the ruler: just select a plane and how deep you want to slice through it and see the cross section.
I suspect this is already a feature but I can't find it.
Where and how can I find this?
Thank you very much.
ppemawm
Re: Section analysis view
Postby ppemawm » Sat May 19, 2018 3:07 pm
View->Clipping plane
"It is a poor workman who blames his tools..." ;)
bejant
Postby bejant » Sat May 19, 2018 3:22 pm
Hi geobruce, and welcome! I don't know of a FreeCAD tool does what is shown in the video. It would probably be a nice tool to request in the bug tracker.
You can use the Part WB > Cross Section tool:
but the cross-sections it creates are 2D sections and don't update if they are moved, and the result is probably not what you want.
You could also position a large Cube over a portion of the shapes:
then use a Boolean Difference to subtract the Cube from those Shapes, resulting in what we call "Cuts":
Moving the Cube will cause the Cuts to update, but they do not update in real time.
You could probably do something with a Part Design WB > Datum Plane but I suspect the result is also not what you want (I simply haven't tried that yet).
20180519a-017-sections.fcstd
(32.36 KiB) Downloaded 9 times
OS: Ubuntu 16.04.4 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.17.13522 (Git)
Build type: None
Branch: releases/FreeCAD-0-17
Hash: 3bb5ff4e70c0c526f2d9dd69b1004155b2f527f2
Python version: 2.7.12
OCC version: 7.2.0
bejant
Postby bejant » Sat May 19, 2018 3:23 pm
Thanks, I didn't think of that (you posted while I was playing around with my model). What I don't like is that it shows the model as being hollow (I already put in a ticket for that).
geobruce
Postby geobruce » Sat May 19, 2018 3:51 pm
thank you this is what I was looking for, when I look at my object with the clipping plane it's empty on the inside. Is there a way to make it solid?
thanks
ppemawm
Postby ppemawm » Sat May 19, 2018 5:03 pm
If you search the Help Forum with 'clipping plane' you will eventually find this wmayer 'trick':
https://forum.freecadweb.org/viewtopic. ... ane#p34648
In the preferences under Display > 3d view you can enable a backlight and define a different color. If you now select your shape and change its Lighting property from "Two side" to "One side" the inner color changes. However, you still have the shading effect. If you again go to the preferences and switch off the backlight the inner becomes totally black.
Or, you can also use Arch=>ArchSectionPlane, although not as convenient if working in PartDesign.
geobruce
Postby geobruce » Sat May 19, 2018 5:41 pm
Thank you, this helped a lot, I'll record a video of it to help other people too.
Bance
Postby Bance » Sun May 20, 2018 11:57 am
Perhaps you should look at this thread:-
https://forum.freecadweb.org/viewtopic.php?f=3&t=28338
HTH Steve
NormandC
Postby NormandC » Sun May 20, 2018 3:37 pm
Very nice Fusion360 feature!
May be relevant as a workaround, Macro_cross_section
dbecad
Postby dbecad » Sun May 20, 2018 5:33 pm
To be noted, this macro does not works with parts and bodies placements, I'm working on an update because I needed the cross-section mechanism for another project.
Cheers
