Hi everybody, I'm trying to extrude a shape from a DXF file that I successfully imported, attached freecad file.
After DXF import I find about ~170 shapes, the problem it I can't join the shapes, I get the error message
"Unable to upgrade these objects."
take for example shapes 160, 161, 162, 163
anybody has any ideas?
thanks
unable to extrude 2D DXF
- extrude_3030.FCStd
- (137.06 KiB) Downloaded 14 times
Re: unable to extrude 2D DXF
Hi sherifeid, welcome to the FreeCAD forum. Did you check in Preferences->Import-Export->DXF the checkbox "JoinGeometry" before importing?
Tested this, but didn't work for me
So, i had to to it manually
- select all shapes and PartWB: [Part]->[Compound]->[make Compound]
- select Compound and DraftWB: [Draft]->[Draft to Sketch]
- select Sketch and SketcherWB: [Sketch]->[validate Sketch]->[Find missing coind.]
- followed by [Sketch]->[validate Sketch]->[Fix missing coind.]
- select Sketch and PartWB: [Part]->[Extrude]
done with:
Version: 0.18.13892 (Git)
Hash: 23f58f1afc710c6189ac44414c8696e8e838535c
Python version: 2.7.14
OCC version: 7.2.0
thanks a lot @UR_
that worked for me
that worked for me
