hello,
Ive noticed strange behaviour: when creating an opening /eg door/
I need to declare a height because a door is window height by default.
And if I dont type units /eg CM/ after a number - I get height in milimeters
and not the units have been set in PREFERENCES ??.
In other words: I always set CM units in Preferences.
By default a door is window height. /100cm?/
Typing '200' makes a 200mm door height,
I need to add 'CM' after that number to obtain correct door.
Why so?
v.18 & opening height
cheers,
Re: v.18 & opening height
I think that the units should be whatever the user has chosen in Preferences. I guess that got overlooked, but maybe Yorik will know. The same thing exists in Preferences > Draft WB > Text and Dimension settings too.
We just had a somewhat similar situation reported here:
https://forum.freecadweb.org/viewtopic. ... 49#p242733
It might be more meaningful if you change the title to something like "0.18 Arch Window / Door Height".
OS: Ubuntu 16.04.4 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.18.14001 (Git)
Build type: None
Hash: 6014fce390390526f3d74672e79e3d8bc994225e
Python version: 2.7.12
OCC version: 7.2.0
yorik wrote: Can you provide some insight for us? Thanks - I'll write a ticket if you want.
Build type: None
OCC version: 7.2.0
