create a changed-fillet.
Hi,all
I want to make a changed-fillet,I don't have no idae to do it. I think I could make it by another way... I sweep it,but I coundn't get what I want.
Thanks for any helps first.
eason.
eason.
Re: create a changed-fillet.
And what ist it what you want?
Align two line.
like this: I use but...
I suppose if Eason is talking about fillet, a quarter circle section tangent to the 2 curved paths?
Another way to think about it would be is there an way to create a fillet from maybe the reverse solid and a boolean operation, that would allow one to get creative with changing radius fillet?
Cheers
Using PartDesign, you can AdditivePipe (Sweeping with Lofting) with multiple sections and a Path. The panel has a Transform option with Multi sections... Created two Datum Planes to sketch mid and end sections...
[Added second screenshot]
MAC OSX Sierra
3D Parts & Links (made using FreeCad and Solidworks): https://www.thingiverse.com/Still_Breathing/designs
Android App & Links: https://play.google.com/store/apps/deta ... .bestknots
Looks like a job for the curves workbench, sweep on two rails.
https://forum.freecadweb.org/viewtopic. ... 52#p176052
Thanks,it is.freecad-heini-1 wrote: ↑Thu Jul 05, 2018 6:01 pm Looks like a job for the curves workbench, sweep on two rails.
Chris_G is the master. Please ask him or try by yourself.eason wrote: ↑Fri Jul 06, 2018 1:21 amThanks,it is.freecad-heini-1 wrote: ↑Thu Jul 05, 2018 6:01 pm Looks like a job for the curves workbench, sweep on two rails.
Chris_G wrote: "Ping"
Explaining the detailed process would be a bit long, but here is what I managed to get:
Hi Chris,
thank you so much. I analyzed your model and understood how you created it. Not so easy.
Clever the sweep between the two lines and the ruled face as base for the two rails sweep.
I will try to find a more easy solution using the surface workbench.
Best regards
Wilfried
