Ticket #3537 - Draft Edit mode not working on MacOS X (HiDPi issue)
Re: Draft Edit mode not working
More Mac users please to weigh in !?
I've just tried on a friends windows machine and everything works as it should. So what I'm trying to do on a MAC was correct, it must be a bug somewhere.
Sorry, hopefully last post on this. I've tried downloading v0.16 and this works as it should. Like I mentioned before, I noticed the anchor points to be different. in the v0.16 the anchors are much bigger compared to v0.17 making it much easier to click on.
v0.16
v0.17
v0.16
v0.17
I didn't save the native Gimp2 files, but I still have the .bmp files, which it won't let me upload due to 'invalid extension' error. I used Paint to delete the parts that were not part of the planes. Then in Gimp2 I used the Colors -> Threshold dialog with the slider all the way to one side to make sure all the gray lines were interpreted as black lines. Then Image -> Mode -> Indexed -> 1 bit per pixel -> Convert to do the conversion (though this last step was probably superfluous after the threshold step). Then File -> Export As -> Windows .bmp (Gimp2 doesn't export to SVG unfortunately). Then I used the online svg converter, but inkscape will probably do just as good a job (never used that software).
I'm attaching planes2.FCStd, which contains the imported objects (Path objects), sketches created from those, and some DWire objects I created from the paths using one of my macros (FCBmpImport). The DWires are discretized, basically a sequential collection of points, so might not be of much use. The sketches are bsplines, but not so many per sketch, so more manageable for the editor to deal with.
- planes2.FCStd
- (101.46 KiB) Downloaded 31 times
It's of course important to know that it is not a handling issue from your side. Currently there are som eproblems with compiling FreeCAD for Mac, but as soon as they are solved you may rebump this discussion if the problem persists.
A final question: Do you use an external monitor? We had some (other) issues with those.
I have checked that our versions are the same and realized that in your first post you don't have any locale information, although besides that you have the same version. So it should of course deliver the locale as well.
How do you notify people that a new version has been released so I can download it and give it ago?It's of course important to know that it is not a handling issue from your side. Currently there are som eproblems with compiling FreeCAD for Mac, but as soon as they are solved you may rebump this discussion if the problem persists.
No, I'm not using an external monitor.A final question: Do you use an external monitor? We had some (other) issues with those.
Locale: English/UnitedKingdom (en_GB)I have checked that our versions are the same and realized that in your first post you don't have any locale information, although besides that you have the same version. So it should of course deliver the locale as well.
there is no notification system. I'm not sure what happened to the program's check on startup if there is a newer version. There where some complaints about automatically opening an internet connection. I simply check https://github.com/FreeCAD/FreeCAD/rele ... g/0.18_pre from time to time.
I had hoped for something exotic explaining the strange behaviour.
Should I raise a ticket in your bug tracking software? Will allow me to follow along as well.chrisb wrote: ↑Fri Jul 13, 2018 9:03 pmthere is no notification system. I'm not sure what happened to the program's check on startup if there is a newer version. There where some complaints about automatically opening an internet connection. I simply check https://github.com/FreeCAD/FreeCAD/rele ... g/0.18_pre from time to time.I had hoped for something exotic explaining the strange behaviour.
Yes, with a link to this discussion and a link from here to the ticket.
