Hello everyone ,
I have been using FreeCad since little less than two months, and I'm coming to you with a quick question, I want to create a pocket inside a solide, but I don't know how to.
The pocket itself is rather complex, I could describe it at an elliptical cone, which would have its end flattened.
It starts with a circle with a diameter of 8 mm and ends up with a large slot, with a height of 5 mm and a width of 35 mm, but the pocket itself is tilted.
As you can see on the attached figures, I have designed the two shapes on the two faces of the solid so that you can better see what I want to achieve.
Basically, I'd like FreeCad to create the pocket using those two shapes as starting and end shapes, but I don't know how to do this, or even if that's possible.
Any ideas on how to achieve this ?
Thank you very much !
Btw, here are my version infos:
Version: 0.17.13522 (Git)
Branch: releases/FreeCAD-0-17
Hash: 3bb5ff4e70c0c526f2d9dd69b1004155b2f527f2
Python version: 2.7.14
OCC version: 7.2.0
Locale: English/Singapore (en_SG)
Help to model complex pocket
Re: Help to model complex pocket
Hi DLG, welcome to the forum.
If you have modeled your cube in PartDesign workbench you create a subtractive loft.
If you have modeled in Part workbench you create a loft and make a boolean cut.
In both cases it works best if you change the circle to consist of several segments matching the segments of the slot.
Hi
I made it in Part Wb
- difuseur.FCStd
- (28.45 KiB) Downloaded 13 times
Hi, this model can also be made in the Part design workbench using the subtractive loft function
- Subtractive loft.fcstd
- (24.16 KiB) Downloaded 12 times
Thanks a lot guys, that was really helpful of you !
