Unable to connect to SpaceNavigator with FreeCAD 0.17 on Fedora 28
Re: Unable to connect to SpaceNavigator with FreeCAD 0.17 on Fedora 28
AFAIK the Ubuntu PPA package is compiled with spacenav support. I'll test when I get the chance and report back.
Do you mean getting the SpaceNavigator running in general or on Fedora in specific? I am not sure how quickly I could do this, but I might be able try this on a Debian-based Raspberry Pi 3 (the only other Linux-based machine I have access to, despite of my Fedora production system). Which however, could lead to totally different problems because of the ARM-architecture and could lead to the general issues described here.
On linux, any flavour. I want to narrow the problem down. I won't be able to do any tests myself for a next 2 weeks.
- tanderson69
I have been using my serial magellan for years in freecad on debian and kubuntu. The best thing you can do is get the 'simple_x11' test program working that I mentioned in my previous post. If that test program works, the problem is with freecad. If that test program doesn't work, the problem is with spacenav.
Tried to use simple_x11 after compiling from source which does not work either. See terminal snippets below for further information:tanderson69 wrote: ↑Tue Jul 17, 2018 10:59 am The best thing you can do is get the 'simple_x11' test program working that I mentioned in my previous post. If that test program works, the problem is with freecad. If that test program doesn't work, the problem is with spacenav.
# download source code, extract, configure and compile test program
$ wget -O liblibspnav.tar https://sourceforge.net/projects/spacenav/files/spacenav%20library%20%28SDK%29/libspnav%200.2.3/libspnav-0.2.3.tar.gz/download
$ tar xf libspnav.tar
$ cd libspnav-0.2.3
$ ./configure
$ cd examples/simple/ ; make
# start spacenavd and double-check status
$ sudo systemctl start spacenavd.service
$ sudo systemctl status spacenavd.service
● spacenavd.service - 3Dconnexion Input Devices Userspace Driver
Loaded: loaded (/usr/lib/systemd/system/spacenavd.service; disabled; vendor preset: disabled)
Active: active (running) since Tue 2018-07-17 21:07:52 CEST; 5min ago
Process: 17596 ExecStart=/usr/bin/spacenavd (code=exited, status=0/SUCCESS)
Main PID: 17597 (spacenavd)
Tasks: 1 (limit: 4700)
Memory: 576.0K
CGroup: /system.slice/spacenavd.service
└─17597 /usr/bin/spacenavd
Jul 17 21:07:52 localhost.localdomain systemd[1]: Starting 3Dconnexion Input Devices Userspace Driver...
Jul 17 21:07:52 localhost.localdomain systemd[1]: Started 3Dconnexion Input Devices Userspace Driver.
# execute test program `simple_x11`
$ ./simple_x11
failed to connect to the space navigator daemon
# however, accessing the unix socket works
$ ./simple_af_unix
got motion event: t(0, -60, -61) r(0, 0, 0)
got motion event: t(0, -60, -61) r(-18, 0, 0)
got motion event: t(97, -66, 10) r(-18, 0, 0)
got motion event: t(97, -66, 10) r(-183, -23, 180)
got motion event: t(54, -57, -23) r(-183, -23, 180)
# connecting to daemon via x11 bindings with disabled access control not working as well
$ sudo xhost +
access control disabled, clients can connect from any host
$ sudo systemctl restart spacenavd.service
$ ./simple_x11
- tanderson69
Now we know that freecad is not the problem....or at least not the only problem.albert.emil wrote: ↑Tue Jul 17, 2018 7:27 pm Tried to use simple_x11 after compiling from source which does not work either.
I would try to run spacenav outside the service/daemon framework. like so:
shutdown the spacenavd service.
as root run, 'spacenavd -d'
run the simple x11 example again and see if it connects.
Just some remarks:
The function call is:
and the question is whether spnav_x11_open is the culprit or that QX11Info::display() returns something wrong/invalid.
- When compiling FreeCAD on a Linux system it tries to find the package Spnav when running cmake configure
- If the Spnav package was found the preprocessor define "-DSPNAV_FOUND" for the FreeCADGui target is set
- GuiApplicationNativeEventAware.cpp is the only file where we use the C-API of the spnav package. On startup we e.g. use the function spnav_x11_open to try to connect to the device.
spnav_x11_open(QX11Info::display(), window->winId())
According to
In a second terminal, I then ran simple_x11 again, which is working:
I open FreeCAD 0.18_pre, where my SpaceNavigator still does not work (might be a issue due to unstable development version). So I downloaded the AppImage version of FreeCAD 0.17 another time, which according to
before starting both _spacenavd_ and _FreeCAD_ does not seem to be neccessary. As a last step I tried to use
instead of the suggested
which does not work. Running spacenavd as a service seems to be a known issue, as you can see from the comments of the 0.6-1 package in the AUR (Arch Linux User Repository). Unfortunately, none of the suggested solutions worked for me.
All in all, regarding FreeCAD 0.17 AppImage running on Fedora 28 with spacenavd-0.6-7.fc28.src.rpm (installed via dnf) I would summarize our findings as:
in order to circumvent any permission issues when connecting to the X-Server. I tried this and rebooted the machine thereafter, but it did not solve the problem. Having a look at
indicates that the Xauthority file used to access X11 is indeed the one I copied to root user's home directory. Despite being more a general Linux or even systemd related question, is there any way to solve this permission issue and being able to use systemd to start spacenavd as desired? I had a look at its service file located at /usr/lib/systemd/system/spacenavd.service, but did not find to get it running properly since the ExecStart command is pretty much the same as for sudo spacenavd:
Using systemd to manage spacenavd with proper XAUTHORITY might work by creating a user-based service (see Arch Wiki or this SO question for further information), but I did not figure out how to do this properly...
running spacenavd -d as root user:
$ sudo spacenavd -d
Spacenav daemon 0.6
failed to open config file /etc/spnavrc: No such file or directory. using defaults.
adding device.
failed to open device: No such file or directory
removing device:
adding device.
device name: 3Dconnexion SpaceNavigator
using device: /dev/input/event2
$ ./simple_x11
got motion event: t(21, -10, 4) r(-9, 4, 0)
got motion event: t(21, -10, 4) r(10, 4, 9)
got motion event: t(21, -19, -6) r(10, 4, 9)
got motion event: t(21, -19, -6) r(10, 4, 26)
got motion event: t(21, -25, -2) r(10, 4, 26)
got motion event: t(21, -25, -2) r(3, 4, 47)
got motion event: t(21, -34, -14) r(3, 4, 47)
got motion event: t(21, -34, -14) r(37, 4, 30)
got motion event: t(21, -50, -40) r(37, 4, 30)
should have spnav support enabled. After all, my SpaceNavigator is shown in the Customize dialog with both motion and button settings available. I can use the SpaceNavigator for 3D navigation (zoom, pan, tilt ...) inside different workbenches as desired. Calling
$ sudo xhost +
$ sudo spacenavd -d
- AppImage is compiled with spacenavd support
- Installing spacenavd by sudo yum install spacenavd works in general for using 3Dconnexion devices, but does not start the required service automatically (neither after installation nor after reboot)
- Running spacenavd as a serice instead of an application leads to faulty behaviour with different solution discussed in the AUR (none of them worked for me)
- Not working SpaceNavigator definitely is/was a issue related to spacenavd, not to FreeCAD (at least in version 0.17)
- spacenavd issue is related to its service not to the application/driver itself (see links above)
- spacenavd.service seems to be unable to connect to the X-Server because of permission issues
sudo cp /run/user/1000/gdm/Xauthority /root/.Xuthority
$ sudo spacenavd -d -v
Spacenav daemon 0.6
Device detection, parsing /proc/bus/input/devices
found usb device [46d:c626]: "3Dconnexion SpaceNavigator" (/dev/input/leds)
adding device.
removing device:
adding device.
Number of axes: 6
trying to open X11 display ":1"
XAUTHORITY=/run/user/1000/gdm/Xauthority
[Unit]
Description=3Dconnexion Input Devices Userspace Driver
After=syslog.target
[Service]
Type=forking
PIDFile=/var/run/spnavd.pid
StandardError=syslog
[Install]
WantedBy=graphical.target
- tanderson69
I am thinking maybe permissions are not your only problem with starting spacenavd with x11 as a service. According to: https://unix.stackexchange.com/question ... 685#360685 The xserver isn't running at the time of the spacenavd service launch, therefore can't connect to the xserver.albert.emil wrote: ↑Wed Jul 18, 2018 7:35 pm related question, is there any way to solve this permission issue and being able to use systemd to start spacenavd as desired?
back in your original post:
did you try to start x11 manually as root?albert.emil wrote: ↑Sat Jul 14, 2018 10:24 pmCode: Select all
$ spnavd_ctl x11 start You must have an X server running before starting up spacenavd-X11 events.
Related thread: https://forum.freecadweb.org/viewtopic.php?t=24650
I got the 3dconnexion device working with python:
but when I try to use spnav_x11_open (python) with pygame it dies with connection problem:
spnav_x11_open (python) is the same as C++ mentioned by wmayer. It calls
where
$ cat 3dconn_test.py
import spnav
spnav.spnav_open()
while 1:
event = spnav.spnav_poll_event()
if event:
print(event)
fedora:/home/przemo/software/3Dconnexion
$ python 3dconn_test.py
SPNAV_EVENT_MOTION trans(-139,-58,27) rot(17,11,16)
SPNAV_EVENT_MOTION trans(-139,-58,27) rot(14,11,16)
SPNAV_EVENT_MOTION trans(-55,-58,51) rot(14,11,16)
SPNAV_EVENT_MOTION trans(-55,-58,51) rot(-47,11,-37)
SPNAV_EVENT_MOTION trans(-100,-23,30) rot(-47,11,-37)
SPNAV_EVENT_MOTION trans(-100,-23,30) rot(-47,20,-37)
SPNAV_EVENT_MOTION trans(-78,-23,6) rot(-47,20,-37)
SPNAV_EVENT_MOTION trans(-78,-23,6) rot(-3,20,-37)
SPNAV_EVENT_MOTION trans(-9,5,6) rot(-3,20,-37)
SPNAV_EVENT_MOTION trans(-9,5,6) rot(2,-3,-10)
$ cat 3dconn_test_pygame.py
import spnav
import pygame
pygame.init()
pygame.event.set_grab(True)
screen = pygame.display.set_mode((400, 400))
spnav.spnav_open()
wm_info = pygame.display.get_wm_info()
print(wm_info["display"])
print(wm_info["window"])
spnav.spnav_x11_open(wm_info["display"], wm_info["window"])
$ python 3dconn_test_pygame.py
<capsule object "display" at 0x7f5dc2ed85a0>
39845903
File "3dconn_test_pygame.py", line 11, in <module>
File "/usr/lib/python2.7/site-packages/spnav/__init__.py", line 216, in spnav_x11_open
'failed to connect to the space navigator daemon')
spnav.SpnavConnectionException: failed to connect to the space navigator daemon
libspnav.spnav_x11_open(display_ptr, window)
libspnav = cdll.LoadLibrary('libspnav.so')
