Polar Pattern count missmatch
freedman
Re: Polar Pattern count missmatch
Postby freedman » Sun Jul 22, 2018 7:33 am
So we have to remember to add one extra unless it's a full circle. I'm not very good at remembering stuff like that but I also don't see any other way to do it.
Am I right, then in thinking the degrees is to the start of the final occurrence rather than after it
I guess they had to do that because there really is no reliable way to know the width of the pocket feature. But they do it in a full circle. Hmmm.
Postby chrisb » Sun Jul 22, 2018 7:49 am
For the angle of the polar pattern you can use Expressions, i.e in your case you enter Revolution.Angle.
Postby chrisb » Sun Jul 22, 2018 8:17 am
Here is an even better expression, which uses the number of occurrences and respects the angle:
Revolution.Angle * (Occurrences-1) / Occurrences
which is the same as
Revolution.Angle * (1 - 1 / Occurrences)
Postby chrisb » Sun Jul 22, 2018 8:35 am
When fiddling around because I had the feeling that it contained too much I found something interesting in Sketch002:
When I delete the selected construction line at the right bottom
Bildschirmfoto 2018-07-22 um 10.29.08.png (35.38 KiB) Viewed 165 times
the sketch is shown in white instead of green and the solver tells me
Bildschirmfoto 2018-07-22 um 10.33.14.png (10.08 KiB) Viewed 165 times
abdullah wrote:abdullah
is this interesting for you?
OS: Mac OS X
Version: 0.18.13976 (Git)
Branch: (HEAD detached at fae0de5)
Hash: fae0de58581694157a97d567c151bdce75d387dc
Python version: 2.7.15
Qt version: 5.11.0
OCC version: 7.2.0
Postby chrisb » Sun Jul 22, 2018 8:49 am
In case it helps, I have minimized the "unsolved" producing model:
Gear_cb.FCStd
(3.42 KiB) Downloaded 7 times
freedman
Postby freedman » Sun Jul 22, 2018 6:28 pm
Postby chrisb » Sun Jul 22, 2018 12:17 am
Can you post how these are to be used in the GUI.
Thanks
TheMarkster
Postby TheMarkster » Sun Jul 22, 2018 7:33 pm
chrisb wrote:
Sun Jul 22, 2018 6:45 am
The misunderstanding might be the following:
The angle defines where the last occurrence starts, not where it ends. The case 360° might lead to confusion, because it is treated special by guessing that you in fact want to have the occurrences distributed evenly around the whole circle.
Ah, now I see. 360° is treated specially. I was wondering about that. Angle would be from start of first element to start of last element, thus we can expect the same results for 12 elements in a full circle with either 360° or 360 * 11/12 (330°).
Note also how 360.0° is treated differently from 360.01° (with draft array)
polar angles.gif (299.46 KiB) Viewed 147 times
abdullah
Postby abdullah » Thu Sep 20, 2018 6:31 pm
Sure it is!
I do not have much time ATM. I have played with the reduced sketch and the behaviour does not seem right. Could you create a ticket with it so that it does not get lost? I might not be available until Mid-October...
Postby chrisb » Thu Sep 20, 2018 6:43 pm
Voluntary; I will do so in the next days, I have the feeling that I could even simplify it further and I might have created a ticket.
Postby chrisb » Fri Sep 21, 2018 1:34 pm
I added a reference to this topic in issue #3589
cron
