Thank you.
I just tried with FreeCAD_0.19-17175-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage.
The SVG is imported, but only partially.
The SVG has been made by hand: a definition section provides half of the content, then the external circle is drawn, the definition is drawn, and the definition is drawn again with a negative scale on the X to reverse the drawing. The combination of the two provides the full content of the circle. Here is the actual SVG:
<svg version="1.1"
baseProfile="full"
width="22mm" height="22mm"
viewBox="-11 -11 22 22"
xmlns="http://www.w3.org/2000/svg"
xmlns:xlink="http://www.w3.org/1999/xlink">
<g transform="scale(1,-1)" stroke="black" stroke-width="0.2" stroke-linecap="round" stroke-linejoin="round" fill="none">
<defs>
<g id="half">
<polyline id="body" points="-1,4 -1.5,4 -1.5,4.25 -1,4 -0.5,3 0,1.5 -0.25,1.25 -0.25,1 -0.5,0 -0.25,-1 -0.5,-2 -0.5,-3 0,-3.5" />
<polyline id="wing" points="-0.5,0 -1,2 -2,4 -4,5.5 -6,6 -7,6 -7.5,5.5 -7.5,5 -7,3 -7,0 -6.5,-1 -6,-1.25 -5,-1.25 -0.25,-1 -1,-2 -1.5,-4 -1.5,-5 -2,-5.75 -3,-6 -3.25,-5.75 -3.75,-5.75 -4,-6 -4.5,-8 -4.5,-5.5 -5,-5 -5,-4.5 -5.5,-4 -5.5,-3.5 -6,-3 -5.75,-2.75 -5.75,-2.25 -6,-2 -5.5,-1.25" />
<g id="lower-wing-details">
<polyline points="-5.5,-1.25 -5.5,-2 -5.25,-3 -4.75,-4 -4,-5 -3.75,-5.75 -3,-4" />
<polyline points="-2,-5.75 -3,-5 -4,-4 -4.5,-3 -4.5,-2 -5,-1.25" />
<polyline points="-6,-2 -0.25,-1 -6,-3" />
<polyline points="-5.5,-4 -4,-3.5" />
<polyline points="-3.5,-4 -5,-5" />
<polyline points="-2,-2 -2,-2.5 -2.5,-3.5 -3,-4 -3.5,-4 -4,-3.5 -4,-3 -3.5,-2.5 -2,-2 -0.25,-1" />
</g>
<g id="upper-wing-details">
<polyline points="-1.5,3 -2.5,1 -2.5,-1 -5,0 -6.5,-1" />
<polyline points="-7,1 -5,1 -2.5,-1" />
<polyline points="-2.5,0 -5,2 -7,3" />
<polyline points="-7.5,5 -2.5,1" />
<polyline points="-5,3 -6,6" />
<polyline points="-5.5,4.5 -7,6" />
</g>
<g stroke="red">
</g>
</g>
</defs>
<circle id="limit" cx="0" cy="0" r="10.5" />
<use xlink:href="#half"/>
<use xlink:href="#half" transform="scale(-1,1)"/>
</g>
</svg>
