putting sketch perpendicular to another
FC-Architecter
Postby FC-Architecter » Sat Aug 04, 2018 12:29 am
OS: Linux Mint 18.3 Sylvia
Version: 0.17.13528 (Git)
Build type: None
Branch: releases/FreeCAD-0-17
Hash: 5c3f7bf8ec51e2c7187789f7edba71a7aa82a88b
Python version: 2.7.12
I am trying to make an arc with a circle attached to the end point and perpendicular to the arc at the the end.
I will then make a sweep up the arc to create a curved tube.
I will also need to create a sketch and additional features at the far end of the arc. But I think the sweep itself will create a flat disk surface at the far end that I can then attach a sketch of another circle to, and then modify.
So I think it may only be necessary to create the perpendular circle sketch once.
So far I have tried keeping the arc sketch visible when I create the circle sketch, but the arc only shows as a flat line with the endpoints hard to pointpoint so I can't attach the circle precisely.
I can locate the circle sketch001 to the endpoint of the arc if I put a point-to-line constraint on the arc to one of the axes. I tried attaching
Any assistance appreciated.
Here I attached the circle to the arc endpoint by eyeballing it. I don't think that is a precise method.
Last edited by FC-Architecter on Sat Aug 04, 2018 12:53 am, edited 2 times in total.
salp
Re: putting sketch perpendicular to another
Postby salp » Sat Aug 04, 2018 12:49 am
The two sketched do not need to be attached, I used Parts Design workbench.
See the attached file.
Screenshot from 2018-08-03 20-47-37.png (98.42 KiB) Viewed 871 times
SweepExample.fcstd
(9.26 KiB) Downloaded 20 times
OS: Linux Mint 18.2 Sonya
Version: 0.18.14183 (Git)
Build type: None
Hash: 8ef330d19ab4aa0cfd6b9a6d41d51eed30620707
FC-Architecter
Postby FC-Architecter » Sat Aug 04, 2018 1:01 am
Thanks for responding.
I am not very good at analysing other people's files. But I don't see a feature called sweep. So I cannot tell if Frenet was used. Frenet affects how the sweep turns at is moves up the path, right?
How do you know your pipe is precise if you need to use it for industrial purposes?
salp
Postby salp » Sat Aug 04, 2018 1:21 am
It looks like you are using the Parts workbench, I'm not familiar with that.
I used the Parts Design workbench, the 4th icon down the right side of the screen shot.
The Way I use it is to hold down the CTRL key and select both sketches, that in the selection window click on the "Object" button then click on sweep path.
To ensure it's precise you need to constrain both sketches (radius and arc length of the curve, and the radius of the circle), I also use the Tech Draw workbenches and display the dimensions just to make sure.
Hope this helps.
Sal
meme2704
Postby meme2704 » Sat Aug 04, 2018 9:49 am
Hi
I think you want to build a "real" pipe of constant circular section
you must place the sketch of the circle representing the section, and the path representing the curve, rigorously perpendicular to the origin.
So place first (it's not mandatory but it's better when you start) the circle section, in the XY plane for example, constrains the diameter and position OX and OY
In a perpendicular plane XZ for example, place the arc for the path, choose the center point of the curve. it is not necessary to specify the radius of the arc path, only its angle is important
you do the sweep that will be coming from the circle section
Then you use placement to place it in the right angle, and in the right place
This is done with the workshop "Part
With PartDesign, some will offer you the entire gas plant
coude-2.FCStd
(12.68 KiB) Downloaded 16 times
coude.FCStd
(12.34 KiB) Downloaded 16 times
mario52
Postby mario52 » Sat Aug 04, 2018 8:31 pm
hi
try this macro Macro_Perpendicular_To_Wire Image
example arc and circle
EDIT:06-08-2018 20h35 Paris
replace image with appropriate example
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Topological_data_scripting, Dialog creation. My macros on Gist.github.
FC-Architecter
Postby FC-Architecter » Mon Aug 06, 2018 12:59 am
1) I think you mean to make the circle before the arc. The circle should be in the XY plane.
2) then make the arc in the XZ plane.
It seems like using placement is just eyeballing it. Unless you exactly how far the circle center is from the arc end-point in millimeters. If both circle and arc are made starting on the origin but in different planes, that might work.
Maybe that is what you meant here?:"So place first (it's not mandatory but it's better when you start) the circle section, in the XY plane for example, constrains the diameter and position OX and OY"
Otherwise. after 1 and 2 have been done, is there a way to use the point coincidence constraint to join the center of the circle to the end-point of the arc?
I don't quite get the "gas plant" reference.
microelly2
Postby microelly2 » Mon Aug 06, 2018 7:07 am
If you have created the first sketch onto a datum plane
you can create a new datum plane for the 2nd sketch which is perpendicular to the first
You define an attachment condition Objects XZ or YZ
There is another way possible too:
define the attachment by 3 points and use MapMode O-X-N
meme2704
Postby meme2704 » Mon Aug 06, 2018 7:40 am
I meant that if you want to have a pipe of circular section, it is necessary that the tangent to the starting point of the path must be perpendicular to the plane of the section, whatever the position of the path in the space.
"gas plant" is a Franco-French expression for a complex pipe array
FC-Architecter
Postby FC-Architecter » Tue Aug 07, 2018 6:23 am
Thanks for showing how to use the datum plane for this. I just learned about the datum plane in the wiki tutorials.
