cuban chain link
cuban chain link
Does anyone happen to have a cuban chain link? modeled in freecad?
like this?
https://grabcad.com/library/cuban-chain-1
I've watched a tutorial but it was for RHINO
https://www.youtube.com/watch?v=dkvxmYTxIH0
There is also a blender tutorial https://www.youtube.com/watch?v=grtoNEK_u5Y
My basic goal is to create a cuban chain to wrap into this 2mm x 1.75mm groove.
like this?
Re: cuban chain link
I have tried it some time ago, I have to find the FCStd file, but don't expect a great quality.
Estudié ingeniería técnica industrial en España y sólo me ha servido para estar en el paro, no me contratan porque no tengo experiencia, y no tengo experiencia porque no me contratan. No debí estudiar esa carrera.
… FC morning sport. Simple approach to a 3D-Curve.
Using "combined projection curve" from CurvesWB.
- CubanChain.FCStd
- FC.18.14210
- (237.05 KiB) Downloaded 31 times
So how do you edit the s curve. Sketcher says it is an invalid sketch and't can't be edited.
Playing with it, trying to shorten and shrink things so that the chain is 3mm wide vs 50, and the links are 4 mm vs 100, and the diameter is 1mm, and the twist is 90 degrees.
When I shorten the measurement to 5mm, I get a huge curl on the other end of the link sketch.
Hi
My proposal completely handmade in 30 minutes ....
Some grumpy will say "gnan gnan ... Partdesign, gnan gnan ... Datumplan, gnan, gnan ... Body
- chain.FCStd
- (89.87 KiB) Downloaded 34 times
- chain.PNG (69.15 KiB) Viewed 2098 times
30 minutes is hard to beat; at least by me. Gna gna!
...how about this one:
Cheers to Chris_G => no gna gna
- CubanChain4.FCStd
- (33.72 KiB) Downloaded 65 times
I have made this design, the file was too largue for uploading it here in FCStd format (I have compressed it with RAR because it compress more than the internal compressor), but if you find interesting, I can share it in FCStd format in thingiverse.com (where I have some jewellery related designs).scrungy_doolittle wrote: ↑Tue Aug 07, 2018 12:55 am Does anyone happen to have a cuban chain link? modeled in freecad?
like this?
grooved_comfort_band.FCStd
The problem of my link is that the link contains two steeps on the surface, because the torus surfaces are not easy to place.
Also, I don't know the exact differences between "curb" and "cuban" they are made with almost the same process (rolling a silver thick wire (or gold), cutting it, interlocking the links, soldering them, twisting them and flattened them). but sometimes the processes in curb is different, with links made from moulds. My bracelets for example are made from a thick wire. Also, there are variations depending on the size of the mandrel and the wire, a thicker wire on a smaller mandrel allows a more dense result of the bracelet or necklace.
Edit: file removed because they were not interesting, if someone needs them, contact me.
… flattening and an optional grooving of the chain link are only additional boolean operations.
The 3D-curve (as a combination of BSplines) is the essential task.
This and the linear or polar array blow up this file "a little bit" - see above.
