strange model view/splash screen messages
jltott
Postby jltott » Sun Aug 19, 2018 1:03 pm
Hi
Windows 10, Freecad 0.17 build 13528
2 issues:
1. splash screen lists one item as not found, to quick to see what it is but suspect program files/freecad/mod/measure?? - is there a log file anywhere?
2. All model views appear as combination of "as is" and "wireframe" (see attachment)
Graphics card update recently maybe problem (radeon 18.8.1 software for radeon R9 200 series card)
Any one have any ideas please
Screenshot (13).png (246.06 KiB) Viewed 454 times
Many thanks
John
Willem
Re: strange model view/splash screen messages
Postby Willem » Sun Aug 19, 2018 1:28 pm
Welcome to the forum,
one possible answer is that the transparency is not 0, see in the tree view, in this case it is 50
Schermafdruk van 2018-08-19 15-25-03.png (217.25 KiB) Viewed 448 times
jltott
Postby jltott » Sun Aug 19, 2018 1:33 pm
Hi
Many thanks for replying
All transparencies set to 0
I will cut out some further screenshots to show why I think this a problem
NormandC
Postby NormandC » Sun Aug 19, 2018 1:37 pm
Hello jltott,
Welcome to the forum.
Make the report view visible by going to View --> Panels --> Report view. It will display this message and you'll be able to copy-paste it here.
As for a log file, you need to explicitly set a command when launching FreeCAD. I'm not sure but I think you have to start FreeCAD from the command line.
Yes, this is most probably the issue, you are the 3rd person in the past few weeks with an AMD card this happens to after a graphics driver update. Let me try to locate the previous topic.
jltott
Postby jltott » Sun Aug 19, 2018 1:37 pm
try and make sense of this if possible
jltott
Postby jltott » Sun Aug 19, 2018 1:50 pm
Nothing in report view when you do this - problem is when you start FreeCad in the splash screen.
Do you know the command line instruction and flags to set report?
Many thanks, much appreciated
NormandC
Postby NormandC » Sun Aug 19, 2018 1:59 pm
Finally found the topic by scanning through the forum index page by page, as the search engine was useless :? It was at the bottom of the 3rd page, and last active a mere 7 days ago. This forum is quite active :D
Unable to hide hidden geometry
In the next to last reply in page 2, crazyraph said he downgraded the Radeon driver to the stable version 18.5.1 and it fixed it.
Still, it's odd that Blender (another 3D app that relies on Open GL) has no issue with the updated August driver.
If it's not in the report view, I wouldn't worry too much about it, still, I wonder if it might give us clues on the graphics issue.
There's a wiki page about it, see Start up and Configuration. I'm afraid I don't know how to apply this info, as I don't have Windows at home.
Postby chrisb » Sun Aug 19, 2018 2:02 pm
I think you don't have to start from the commandline, you can set the additional parameters in the properties of the startup icon.
NormandC
Postby NormandC » Sun Aug 19, 2018 2:06 pm
Might be worth a try, from what I can understand you'd just have to add a trailing space and -l (that's a lowercase L) at the end of the exec path. FreeCAD.log will be saved in the same folder as the config files (in %APPDATA%\FreeCAD).
GeneFC
Postby GeneFC » Sun Aug 19, 2018 2:34 pm
That method works for me. No command line needed.
OS: Windows 7
Version: 0.18.14315 (Git)
Hash: 5f8f26824486b55b2bf72c579e95f0f6d4a19284
Python version: 2.7.14
OCC version: 7.2.0
Gene
