strange model view/splash screen messages
Re: strange model view/splash screen messages
Thanks Gene. This should be added to the wiki...
Thanks all for your help.
For information, rolling back the driver on the Radeon card cured the problem with the strange model view, so thank you to everyone for the help on that, greatly appreciated. Time now to pester Radeon I think.
On the splash screen, obviously a seperate issue which does not cause any problems that I have yet found, will post if I find anything.
Thanks folks
Thanks folks
Glad this solved your problem!
Done, added a new subsection "Using command line options without a command line shell" http://www.freecadweb.org/wiki/Start%20 ... figuration. Windows and Ubuntu users please validate.
In case someone is interested i have a R9 380 and i tested the 0.18 beta with the last version of GPU driver 18.11.2 and it works with no transparency problem .
Perhaps the developer team can use this to track what cause the transparency problem in 0.17 and maybe make a update to fixit?
Hi GeekinaCave, welcome to the forum and thanks for reporting back.GeekinaCave wrote: ↑Fri Nov 23, 2018 1:53 am In case someone is interested i have a R9 380 and i tested the 0.18 beta with the last version of GPU driver 18.11.2 and it works with no transparency problem .
The 0.18 release is before the doors, so I guess there will be no backports.
