How to resize a rectangle edge only in one dimension? (PartDesign)
ceremcem
Post by ceremcem »
When I move a rectangle edge with mouse, it also affects the other connected edges' positions, like so:
I tried pressing and holding Ctrl or Shift like I do for drawing perpendicular line in Gimp, but they seem to have no effect.
How can I drag the lines only in perpendicular directions?
DeepSOIC
Re: How to resize a rectangle edge only in one dimension? (PartDesign)
Post by DeepSOIC »
Use constraints.
Aligned your top side -> Vert Distance constraint to one of involved points -> adjust left side -> horz constraint to a corner -> ....
EDIT: you can also grab points. This moves less stuff all at once.
NormandC
Post by NormandC »
ceremcem wrote: Sat Aug 25, 2018 11:24 pm I tried pressing and holding Ctrl or Shift like I do for drawing perpendicular line
That might be a good Sketcher enhancement request.
ceremcem
Post by ceremcem »
DeepSOIC wrote: Sun Aug 26, 2018 12:09 am Use constraints.
Grabbing points is helpful, thank you. (I was going to say "Grabbing points is helpful when you can grab one, but it seems it's not always possible: [gif here]" but I didn't come across with that case in these days)
NormandC wrote: Sun Aug 26, 2018 4:55 am That might be a good Sketcher enhancement request.
https://www.freecadweb.org/tracker/view.php?id=3576
DeepSOIC
Post by DeepSOIC »
ceremcem wrote: Fri Aug 31, 2018 11:25 pm (I was going to say "Grabbing points is helpful when you can grab one, but it seems it's not always possible: [gif here]" but I didn't come across with that case in these days)
On the gif you posted, it looks like you are editing a sketch from behind. Then, indeed, points are not grabbable. It is because points are raised above the sketch in a particular direction (maybe some day, that direction will be towards camera rather than along sketch plane normal).
ceremcem
Post by ceremcem »
DeepSOIC wrote: Fri Aug 31, 2018 11:29 pm On the gif you posted, it looks like you are editing a sketch from behind. Then, indeed, points are not grabbable.
A-ha! Thanks for this additional tip.
Post by Kunda1 »
DeepSOIC wrote: Fri Aug 31, 2018 11:29 pm On the gif you posted, it looks like you are editing a sketch from behind. Then, indeed, points are not grabbable. It is because points are raised above the sketch in a particular direction (maybe some day, that direction will be towards camera rather than along sketch plane normal).
Is there a feature ticket opened for that as well? That seems like a useful ability.
NormandC
Post by NormandC »
I edited the summary and description to make it clearer.
Also, "PartDesign" was set as project, but this is about the Sketcher, so I moved it to the appropriate project.
Thanks for reporting.
Polyline got during the last Sketcher enhancement period a possibility for arc mode to continue by snapped degrees of multiples of 45°. This is done by pressing the Ctrl key. Here it is analogous, so I would vote for the Ctrl key as well.
ceremcem
Post by ceremcem »
NormandC wrote: Sat Sep 01, 2018 3:41 pm
Thank you, it's very kind to let me know.
