Addon Manager not working in Py3 build with metadata.txt
furti
Postby furti » Mon Aug 27, 2018 7:49 pm
I tested the 0.18 Py3 build today and wanted to install Yoriks BIM Workbench. But it failed with the following error:
No module named 'git'
GitPython not found. Using standard download instead.
  File "C:\Meine Daten\freecad\FreeCAD_0.18.14443_Conda_Py3QT5-WinVS2016_x64\Mod\AddonManager\AddonManager.py", line 958, in run
    depsok,answer = self.checkDependencies(self.repos[idx][1])
  File "C:\Meine Daten\freecad\FreeCAD_0.18.14443_Conda_Py3QT5-WinVS2016_x64\Mod\AddonManager\AddonManager.py", line 1013, in checkDependencies
    deps = depsfile.split("\n")
TypeError: a bytes-like object is required, not 'str'
Some googling brought me to the result that urllib2 gives you a bytestring and not a unicode string like in Python 2.7.
The fix for me was to append this code on line 1006 in AddonManager.py
            # urllib2 gives us a bytelike object instead of a string. Have to account for that
            try:
                depsfile = depsfile.decode('utf-8')
            except AttributeError:
                pass
I have a Pretty bad Internet connection Right now. So i can't clone the FreeCAD repository and add the fix. Feel free to incorporate the code into FreeCAD. Otherwise i might create a pull request at the end of the week when my Internet connection will be better again :D
The FreeCAD Version i used:
Version: 0.18.14442 (Git)
Hash: bb9d737ba1158fdba5d06df45ab3e213065139cd
Python version: 3.6.6
Qt version: 5.6.2
Locale: German/Austria (de_AT)
Bugfix also testet in Version:
Version: 0.18.13870 (Git)
Hash: f0964a9c052ee666631cd9caec1655790964ecb6
Python version: 2.7.14
OCC version: 7.2.0
TheMarkster
Re: Addon Manager not working in Py3 build with metadata.txt
Postby TheMarkster » Mon Aug 27, 2018 8:03 pm
This will probably fix the issue I was having here:
https://forum.freecadweb.org/viewtopic. ... 76#p252190
with a different macro.
My FreeCAD video series on youtube: https://www.youtube.com/playlist?list=P ... GEBlLshYGa
sgrogan
Postby sgrogan » Mon Aug 27, 2018 10:26 pm
No module named 'git' GitPython not found. Using standard download instead.
Thanks for this. I will fix this in the up-coming Conda based Win builds. It's independent from the Py3 issue, but it's a good reminder.
PY3 testing is great :)
EDIT: https://github.com/FreeCAD/FreeCAD/rele ... 016_x64.7z should fix the git part of the packaging. Do you have time to test furti?
looo
Postby looo » Tue Aug 28, 2018 8:48 am
furti wrote:I have a Pretty bad Internet connection Right now. So i can't clone the FreeCAD repository and add the fix. Feel free to incorporate the code into FreeCAD. Otherwise i might create a pull request at the end of the week when my Internet connection will be better again :D
you can make changes to freecad also via github directly. simple browse to the file you want to edit, and press on the editing symbol on the top right (see image). The steps to create the PR are also intuitive...
Bildschirmfoto vom 2018-08-28 10-43-32.png (57.94 KiB) Viewed 510 times
please help with my conda-packaging efforts: https://liberapay.com/looooo/
minimalistic blog: https://looooo.github.io/mini-blog/
furti
Postby furti » Tue Aug 28, 2018 3:27 pm
Downloaded the new build provided by you ( seems that the Internet connection is better earlier in the day when not everyone is Streaming in the hotel :D )
Now the git not found message is gone :)
Thanks for that hint. Don't work with the Github GUI that much so I didn't think about that :) Created a Pull Request to fix this issue now.
furti
Postby furti » Tue Aug 28, 2018 3:52 pm
Found one thing that looks like a bug with the git download method. When Installing the Dialog says cloning. Thats fine
But when the Installation is finished there is no Information about it. The dialog simply returns to its initial state.
After Reopening the Addon Manager (no FreeCAD restart needed) it Shows that the workbench is installed.
There is also a icon missing for the "Check for updates" Button. :)
Tested with:
Version: 0.18.14482 (Git)
Hash: 6f06345634e25839b535a4534face9d9c1196201
Qt version: 5.6.2
UR_
Postby UR_ » Tue Aug 28, 2018 4:51 pm
using this build, i got following messages in report view:
Failed to initialize: Bad git executable.
The git executable must be specified in one of the following ways:
    - be included in your $PATH
    - be set via $GIT_PYTHON_GIT_EXECUTABLE
    - explicitly set via git.refresh()
All git commands will error until this is rectified.
This initial warning can be silenced or aggravated in the future by setting the
$GIT_PYTHON_REFRESH environment variable. Use one of the following values:
    - quiet|q|silence|s|none|n|0: for no warning or exception
    - warn|w|warning|1: for a printed warning
    - error|e|raise|r|2: for a raised exception
Example:
    export GIT_PYTHON_REFRESH=quiet
Downloading https://github.com/tomate44/CurvesWB/archive/master.zip
UR_
Postby UR_ » Tue Aug 28, 2018 5:17 pm
Sorry for that false positive, just didn't realize that git wasn't installed on machine I used for testing :oops:
UR_
Postby UR_ » Tue Aug 28, 2018 5:26 pm
If you try to update a already installed WB, you will get lost in a endless loop :(
and you have to leave addon manager by [close] button and reinvoke it to continue :(
TheMarkster
Postby TheMarkster » Tue Aug 28, 2018 5:29 pm
No, that's still a great report. I think most users will not have git installed, especially not on Windows.
