Known OS specific Issues
Postby chrisb » Wed Aug 29, 2018 6:38 am
This topic is locked. For comments go to https://forum.freecadweb.org/viewtopic.php?f=3&t=30574
  • For modeling issues please refer to the FAQ and the Troubleshooting models
  • Startup fails on Debian based system like Ubuntu, Debian, Mint, ...
    FreeCAD startup may fail with the message
    failed to create drawable
    [xcb] Unknown sequence number while processing queue
    [xcb] Most likely this is a multi-threaded client and XInitThreads has not been called
    [xcb] Aborting, sorry about that.
    freecad: xcb_io.c:259: poll_for_event: Assertion `!xcb_xlib_threads_sequence_lost' failed.
    Aborted
    gntech recommends
    gntech wrote:
    Thu Apr 12, 2018 6:04 pm
    A workaround is to disable DRI3 just for Freecad by launching freecad from the terminal with the following command.
    LIBGL_DRI3_DISABLE=true freecad
  • Crash on Debian based systems importing SVG
    Hint from NormandC: The current PPAs fix this by upgrading some dependencies. Users who previously implemented Chris_G's fix mentioned below should revert the change (unlock the expat/libexpat1 packages and update them to the version in the Ubuntu 18.04/18.10 repo) for the PPA update to succeed.
    Outdated message:
    FreeCAD can crash when importing SVG files with a message like
    jalar wrote:
    Wed Jan 10, 2018 1:19 pm
    openat(AT_FDCWD, "/path-to-file.svg", O_RDONLY) = 27
    fstat(27, {st_mode=S_IFREG|0644, st_size=2234752, ...}) = 0
    --- SIGSEGV {si_signo=SIGSEGV, si_code=SEGV_MAPERR, si_addr=0x3a9} ---
    write(2, "\33[1;31m", 7)                = 7
    write(2, "Program received signal SIGSEGV,"..., 53Program received signal SIGSEGV, Segmentation fault.
    ) = 53
    #0  /lib/x86_64-linux-gnu/libc.so.6(+0x37140) [0x7fd97f382140]
    #1  /lib/x86_64-linux-gnu/libexpat.so.1(XML_SetHashSalt+0x1b) [0x7fd976c411cb]
    #2  /usr/lib/python2.7/lib-dynload/pyexpat.x86_64-linux-gnu.so(+0x6968) [0x7fd90487a968]
    As a solution some libraries have to be installed manually:
    Chris_G wrote:
    Thu Apr 19, 2018 8:45 am
    The packages from Ubuntu xenial work fine :
    https://packages.ubuntu.com/xenial/expat
    https://packages.ubuntu.com/xenial/libexpat1
    I have also this one, but I don't know if it is really needed :
    https://packages.ubuntu.com/xenial/libexpat1-dev
    Then in the folder where you downloaded the packages :
    sudo dpkg -i ./expat_2.1.0-7ubuntu0.16.04.3_amd64.deb
    sudo echo expat hold | sudo dpkg --set-selections
    sudo dpkg -i ./libexpat1_2.1.0-7ubuntu0.16.04.3_amd64.deb
    sudo echo libexpat1 hold | sudo dpkg --set-selections
    sudo dpkg -i ./libexpat1-dev_2.1.0-7ubuntu0.16.04.3_amd64.deb
    sudo echo libexpat1-dev hold | sudo dpkg --set-selections
  • Windows display driver
    There are issues with Radeon graphic cards. If your objects show transparency where they should not, it may be caused by the Radeon driver.
    SirSpamalot wrote:
    Tue Aug 28, 2018 10:46 pm
    I have a Radeon RX 460 card. It appears that I updated the driver on July 23, 2018. The updated driver was version 24.20.12019.1010 (from Radeon Driver Package 18.7.1). I rolled it back to the version that was previously installed, 21.19.407.0, and that resolved the problem. I then rolled it forward to 24.20.11016.4 (from Radeon Driver Package 18.5.1) and I still don't have the problem. Yay!
    Here is another report of issues with a Radeon 5470 and a driver solving it: https://forum.freecadweb.org/viewtopic. ... 44#p264835
    A user from the german forum has successfully installed the current driver version 18.12.2 including. Relive für his Radeon R9 380.
    Radeon Vega 64 is said to be working with driver version 18.50.11.01-190109a-337968E-RadeonSoftwareAdrenalin2019. See https://forum.freecadweb.org/viewtopic. ... 40#p281540
  • MacOS: freezing for about a minute on MacOS Mojave (10.14)
    Opening a system dialog on these systems can take extremely long.
    Workaround: start FreeCAD from a console or batch file.
    See https://forum.freecadweb.org/viewtopic.php?f=4&t=31343 for details.
