Known Issues Comments
thomas-neemann
Re: Known Issues Comments
Post by thomas-neemann »
bambuko wrote: Sat Jan 01, 2022 11:00 am ...issues with nvidia drivers on Linux..
this is linus torvalds' opinion on nvidia
https://www.youtube.com/watch?v=f1CP4OwBdLo
phpBB [video]
bambuko
Post by bambuko »
I don't speak Spanish so this video is un-watchable (for me at least).
Anyway... however amusing it is (I am guessing) it doesn't address my problem.
I am stuck with my graphic card and will not be buying another one for quite a while,
so I (and I guess few others in the same position) need a solution.
Happy New Year ;)
I am using Link branch and Assembly3
you can also download ... and try it here
excellent Assembly3 tutorials here
thomas-neemann
bambuko wrote: Sat Jan 01, 2022 11:46 am ...
Happy New Year ;)
Happy new year to you too. I would try a beta driver in your situation:
https://www.nvidia.de/Download/Find.aspx?lang=de
bambuko
Post by bambuko »
This is probably drifting OT (sorry), but just to reply - good suggestion
Even though I was convinced I had the latest drivers there seem to be couple issued only few days ago so maybe this will make difference?
My drivers:
and what is available at the moment (latest dated onlt 13th Dec 2021):
You will see that Beta is older than the latest...
so no point using Beta?
Whether it will make any difference? is another story
Main thing (to me) is publicising Open GL trick
(although I still don't know how to do it if FreeCAD crashes before one can change the setting?)
thomas-neemann
bambuko wrote: Sat Jan 01, 2022 12:12 pm ... I still don't know how to do it if FreeCAD crashes before one can change the setting?)
for this it should be possible to install freecad in a virtual machine or on another pc (without nvidia). this could be used to create the desired settings (files) and copy them to the nvidia pc.
btw here the english version
https://www.youtube.com/watch?v=e8RKWpMwSk4
phpBB [video]
Syres
Post by Syres »
bambuko wrote: Sat Jan 01, 2022 12:12 pm although I still don't know how to do it if FreeCAD crashes before one can change the setting?
The simple way is to execute from a terminal:
export LIBGL_ALWAYS_SOFTWARE=1
then start FreeCAD
which is the equivalent to editing the user.cfg and add this section usually towards the end of the file:
        <FCParamGroup Name="OpenGL">
          <FCBool Name="UseSoftwareOpenGL" Value="1"/>
        </FCParamGroup>
Edit: Proper solution found.
bambuko
Post by bambuko »
thomas-neemann wrote: Sat Jan 01, 2022 12:21 pm btw here the english version
Jolly British of you :mrgreen: :lol:
made me chuckle ;)
PS thank you for advice about changing settings
Scary part about updating nvidia drivers on Linux machines is that interweb is full of the stories of black screens if/when you get it wrong... :twisted:
and to be honest I prefer not to touch word censored - in case it stinks even worse.
Syres
Post by Syres »
This isn't purely a Nvidia driver only problem, as you can see from the log below, I'm running 470.86 with hardware acceleration using the same version of AppImage and my own compiled FC and never had any issue. So either it's the exact card you have interacting with the driver (mine's an old GTX 670) or the distro is a possibility.
12:56:38  OpenGL version is: 4.6 (4.6.0 NVIDIA 470.86)
12:56:38  Run Gui init script
12:56:38  Init: Running FreeCADGuiInit.py start script...
12:56:38  Init:   Searching modules...
12:56:39  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/AddonManager... done
12:56:39  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/Arch... done
12:56:39  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/Draft... done
12:56:39  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/Drawing... done
12:56:39  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/Fem... done
12:56:39  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/Idf(InitGui.py not found)... ignore
12:56:39  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/Image... done
12:56:39  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/Import... done
12:56:39  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/Inspection... done
12:56:39  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/Material... done
12:56:39  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/Measure(InitGui.py not found)... ignore
12:56:39  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/Mesh... done
12:56:40  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/MeshPart... done
12:56:40  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/OpenSCAD... done
12:56:40  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/Part... done
12:56:40  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/PartDesign... done
12:56:40  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/Path... done
12:56:40  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/Points... done
12:56:40  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/Raytracing... done
12:56:40  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/ReverseEngineering... done
12:56:40  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/Robot... done
12:56:40  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/Show(InitGui.py not found)... ignore
12:56:40  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/Sketcher... done
12:56:40  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/Spreadsheet... done
12:56:40  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/Start... done
12:56:40  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/Surface... done
12:56:40  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/TechDraw... done
12:56:40  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/Test... done
12:56:40  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/Tux... done
12:56:40  Init:      Initializing /tmp/.mount_FreeCAdWLgl0/usr/Mod/Web... done
12:56:41  Init:      Initializing /home/john/.local/share/FreeCAD/Mod/fasteners... done
12:56:41  Init:      Initializing /home/john/.local/share/FreeCAD/Mod/Silk... done
12:56:41  Init:      Initializing /home/john/.local/share/FreeCAD/Mod/Plot(InitGui.py not found)... ignore
12:56:41  Module: Part
12:56:41  Loading Part module... done
12:56:41  Init:      Initializing /home/john/.local/share/FreeCAD/Mod/CfdOF/./... done
12:56:41  Packaged workbench  specified icon in class CfdOFWorkbench:
12:56:41   ... Overwriting that specification with package.xml dataInit:      Initializing /home/john/.local/share/FreeCAD/Mod/Curves/./(InitGui.py not found)... ignore
12:56:41  Failed to get handle to CurvesWorkbench -- no icon can be generated, check classname in package.xml
12:56:41  Init:      Initializing /home/john/.local/share/FreeCAD/Mod/fcgear(InitGui.py not found)... ignore
12:56:41  Init:      Initializing /home/john/.local/share/FreeCAD/Mod/ThreadProfile/./... done
12:56:42  Packaged workbench ThreadProfile specified icon in class ThreadProfileWorkbench:
12:56:42   ... Overwriting that specification with package.xml dataInit:      Initializing /home/john/.local/share/FreeCAD/Mod/A2plus... done
12:56:42  Init:      Initializing /home/john/.local/share/FreeCAD/Mod/sheetmetal... done
12:56:42  All modules with GUIs using InitGui.py are now initialized
12:56:42  Init: Initializing freecad.appimage
12:56:42  Init: Initializing freecad.appimage... done
12:56:42  Init: Initializing freecad.asm3
12:56:45  Init: Initializing freecad.asm3... done
12:56:45  Init: Initializing freecad.freecad_glider
12:56:45  Init: Initializing freecad.freecad_glider... done
12:56:46  Init: Initializing freecad.gears
12:56:46  Init: Initializing freecad.gears... done
12:56:46  Init: Initializing freecad.Curves
12:56:46  Init: Initializing freecad.Curves... done
12:56:46  Init: Initializing freecad.plot
12:56:47  Init: Initializing freecad.plot... done
12:56:47  All modules with GUIs initialized using pkgutil are now initialized
12:56:47  Init: Loading FreeCAD GUI
12:56:47  Init: Running FreeCADGuiInit.py start script... done
12:56:52  Init: Activating default workbench StartWorkbench
12:56:52  Loading GUI of Web module... done
12:56:52  Loading GUI of Start module... done
12:56:52  Loading Start module... done
12:56:52  Loading GUI of Part module... done
12:56:52  Init: Showing main window
12:56:52  Main window restored
12:56:52  Show main window
12:56:52  Toolbars restored
12:56:52  Couldn't connect to spacenav daemon. Please ignore if you don't have a spacemouse.
12:56:52  Loading Draft workbench, done.
12:56:52  Draft workbench activated.
12:56:52  Draft workbench deactivated.
12:56:52  Init: Entering event loop
12:56:52  Init: Executing event loop...
12:56:52  Init: Processing command line files
My display settings:
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.20.26720 (Git) AppImage
Branch: (HEAD detached at 7bca26e)
Hash: 7bca26e7c14d4d43374ff7e0c8582735b249cbfd
Python version: 3.9.9
Qt version: 5.12.9
OCC version: 7.5.3
bambuko
Post by bambuko »
Syres wrote: Sat Jan 01, 2022 1:00 pm ...So either it's the exact card you have interacting with the driver (mine's an old GTX 670) ...
Mine is not much younger NVIDIA® GeForce® GTX® 1650 SUPER
Syres wrote: Sat Jan 01, 2022 1:00 pm...or the distro is a possibility...
that is a possibility? I am using elementary OS 6.1 Jalnir (Pantheon) which is not exactly renowned for ability to customise it,
but if you look at the thread that solved my issue (https://forum.freecadweb.org/viewtopic.php?t=63680)
the guy was using Ubuntu 20.04.3 LTS (Budgie:GNOME/budgie-desktop)
so I don't know what the problem really is...
My suspicion is that it might be something Ubuntu related? (common denominator...)
OS: elementary OS 6.1 Jalnir (Pantheon/pantheon)
Qt version: 5.12.9
OCC version: 7.5.3
bambuko wrote: Sat Jan 01, 2022 11:00 am Should the info about solution to issues with nvidia drivers on Linux(ubuntu based) be added to known issues?
Yes, of course. I didn't follow all of the nvidia posts and I don't own one to reproduce. Can you make a proposal what to include in the known issues, please?
Syres wrote: Sat Jan 01, 2022 12:39 pm
Please don't hijack this topic, otherwise important information may get lost.
