Known Issues Comments
Re: Known Issues Comments
I am editing always the same post and it doesn't update the time stamp.
qwerty_f
Post by qwerty_f »
You can get a 0.19 running on Big Sur if you dare to compile it. See https://forum.freecadweb.org/viewtopic. ... 10#p441848
qwerty_f wrote: Wed Dec 16, 2020 10:31 pm You can get a 0.19 running on Big Sur if you dare to compile it. See https://forum.freecadweb.org/viewtopic. ... 10#p441848
Is it meanwhile the current master? I want to use that, because I follow the current Sketcher development.
qwerty_f
Post by qwerty_f »
No. And honestly I'm even stuck in re-installing the version I got up wirh vejmarie's help. But he seems to be off for Christmas and without support I won't get towards Error 2 (I just don't want to dive into homebrew bejond doctor and install...).
JohnOCFII
Post by JohnOCFII »
chrisb wrote: Wed Dec 16, 2020 11:33 pm
You might wish to update the current issues list to show that if you follow the Mini-Conda build instructions (from that same thread, or from the Dr. Vax instructions), you can get the current master.
I'm still curious to know if the people who create the "official" Github nightly builds are aware of the Big Sur issue, and if they have thoughts (or need help) trying to resolve it.
JohnOCFII wrote: Fri Jan 01, 2021 4:25 pm You might wish to update the current issues list to show that if you follow the Mini-Conda build instructions (from that same thread, or from the Dr. Vax instructions), you can get the current master.
Is this a good link to point to: https://forum.freecadweb.org/viewtopic. ... 50#p449550?
A forum discussion does not seem to be a good medium for such instructions, because there are often small things which have to be adjusted in later posts. Can somebody who had run successfully through the procedure create a wiki page for it? Editing that would keep the same page current.
looo wrote: pinged by pinger macro
JohnOCFII
Post by JohnOCFII »
chrisb wrote: Fri Jan 01, 2021 7:00 pm Is this a good link to point to: https://forum.freecadweb.org/viewtopic. ... 50#p449550?
This is a better, more updated and streamlined set of instructions: https://forum.freecadweb.org/viewtopic. ... &start=112
I agree. Irv does link to a web page with instructions from that post.
JohnOCFII
Post by JohnOCFII »
FYI -- as of (at least) https://github.com/FreeCAD/FreeCAD/rele ... -conda.dmg, the 0.19_pre release from Github builds can once again work on Big Sur!
That issue can be removed from the known issues list.
JohnOCFII wrote: Wed Mar 17, 2021 6:48 pm That issue can be removed from the known issues list.
Thanks, I have marked it as solved and will remove it when 0.19 stable is ready.
bambuko
Post by bambuko »
Should the info about solution to issues with nvidia drivers on Linux(ubuntu based) be added to known issues?
I've had problems with it before (https://forum.freecadweb.org/viewtopic. ... 10#p542322) which I thought were solved by updating nvidia drivers.
All was fine until I tried to use 0.20.26720 (Git) AppImage couple of days ago.
despite updated nvidia drivers the symptoms were the same - FreeCAD crashing while loading.
The solution turned out to be (https://forum.freecadweb.org/viewtopic. ... 80#p546204)
I was lucky for FreeCAD to stay on long enough to be able to change preferences to "Use Software OpenGL"
This solved the problem and all is fine (but what could I do if I wasn't able to run FreeCAD long enough to do it?)
Anyway... I found the answer by searching the web and forum but didn't see the answer in Known OS specific issues (https://forum.freecadweb.org/viewtopic.php?f=3&t=30573) hence the question - should this be included (it seems common enough if you search the web....)
OS: elementary OS 6.1 Jólnir (Pantheon/pantheon)
Version: 0.20.26720 (Git) AppImage
Branch: (HEAD detached at 7bca26e)
Hash: 7bca26e7c14d4d43374ff7e0c8582735b249cbfd
Python version: 3.9.9
Qt version: 5.12.9
OCC version: 7.5.3
I am using Link branch and Assembly3
you can also download ... and try it here
excellent Assembly3 tutorials here
