I have a strange problem. I have a model, called house.fcstd, that contains two arcs in addition to other geometry. The arcs disappear when I set the Draw Style Property to anything other than "Solid". In the same model, I created a Line object and had no problems setting the Draw Style property to dashed.
This seems to be related to the configuration of data in my model. I discovered this when I created another model, called TestArc.fcstd, that contains a single arc object. With this one, I do not have any problems setting the Draw Style property to Dashed.
So what is wrong with the house.fcstd model.
My freecad installation information is
OS: Ubuntu 18.04.1 LTS
Version: 0.17.13541 (Git)
Build type: None
Branch: releases/FreeCAD-0-17
Python version: 2.7.15rc1
Problems with Draw Style on Arcs
- TestArc.fcstd
- Contains a single arc object, Draw Style property can be set with no problems.
- (3.3 KiB) Downloaded 7 times
- house.fcstd
- Contains two arcs whose Draw Style property cannot be changed to anything other than solid because the arcs disappear.
- (23.58 KiB) Downloaded 12 times
Re: Problems with Draw Style on Arcs
I have no problem with the house model either...
Maybe something wrong with your graphic drivers? Everything is up to date?
No issue either here.
Build type: None
Locale: French/Canada (fr_CA)
Build type: None
Indeed, the problem is with my platform. I tested the behavior on a Windows box and a different Ubuntu box and found that the Draw Style worked correctly.
I tried updating the open-source drivers but the problem persisted which is not surprising given that the Mobo/Processor pair dates back to 2011.
Thanks for the help.
