Hi, I am trying to import a building floor plan that was originally drawn in QCad and saved as a DXF.
The file opens perfectly in LibreCAD and also in DraftSight, but try as I may I cannot get it to work properly in FreeCAD (both 0.17 and tonight's 0.18).
Image in LibreCAD:
Image in DraftSight:
Image in FreeCAD:
I have tried exporting in various flavours of DXF and also as DWG from both LibreCAD and DraftSight, but the result is the same every time.
I have also tried deleting various parts of the drawing to see if there is a rogue line, and although there is some slight differences, the drawing is still incomplete.
Any help is very welcome!
Missing lines with DXF import
Re: Missing lines with DXF import
Could you share your dxf file so I could try it out and see if I can come with a solution for you?
*EDIT*: Also, one thing that sometimes solves problems with dxf is to select and copy to clipboard all objects from your dxf file, create a new dwg/dxf, paste all objects in this new file and save it with a new name. Then, import this new dxf to FreeCAD.
By default I believe the Legacy Python Importer is not checked, enabling this can fix a lot of DXF import problems. This is found in Edit menu > Preferences > Import-Export > DXF tab as per screenshot:
Click Apply and then OK to ensure the change is made.
Firstly, thanks to both for replying.
I can continue to the next stage now.
Of course, I should have done that. Attached now.Could you share your dxf file so I could try it out and see if I can come with a solution for you?
Hmm, I tried that but it was exactly the same - still bits missing.*EDIT*: Also, one thing that sometimes solves problems with dxf is to select and copy to clipboard all objects from your dxf file, create a new dwg/dxf, paste all objects in this new file and save it with a new name. Then, import this new dxf to FreeCAD.
I wanted to try this, but was having a lot of problems installing the add-on (Add-on Manager kept freezing trying to populate the add-on list). However, I tried again just now and yes - it works !By default I believe the Legacy Python Importer is not checked, enabling this can fix a lot of DXF import problems. This is found in Edit menu > Preferences > Import-Export > DXF tab as per screenshot:
- NONAME_1.dxf
- (58.39 KiB) Downloaded 58 times
I didn't know about the Legacy Python Importer, if that solved the problem that's the most important. In alternative, if you open your DXF with Draftsight, copy all objects to a new DXF file and import again, even with the Legacy Python Importer checked it seems to work. Attached you'll find the new DXF for you to try it out.
- NONAME.dxf
- (108.71 KiB) Downloaded 84 times
Thank you, your DXF also worksif you open your DXF with Draftsight, copy all objects to a new DXF file and import again, even with the Legacy Python Importer checked it seems to work. Attached you'll find the new DXF for you to try it out
I am not sure why I couldn't get the copy method to work last night, maybe it's because I was using Linux Mint. I will try again this evening.
A few years ago I made my own command line interface tool for importing DXFs.
https://framagit.org/MarcusFecit/LibreCadToFreeCad
The tool can also detect basic constraints such as coincidence, tangentiality, horizontality, verticality, etc..
I now have improved it with a Pyside2 QT interface and even a Web interface (Flask).
I hope I will have some time this summer to clean the code, translate it to english and publish it.
What I can say about your DXF file is that the useful part of the design is far away from the origin. Is it what you want ?
Et bonne journée !
Et bonne journée !
Marc BERLIOUX
Marc BERLIOUX
