Torus has no Refine property
Postby chrisb » Fri Sep 07, 2018 12:06 am
PartDesign Additive and Subtractive Torus don't have the Refine property. Should I create a ticket?
OS: macOS High Sierra (10.13)
Version: 0.18.14561 (Git)
Branch: (HEAD detached at 599e590)
Hash: 599e59059b6ffce969c51f77380ba7938eba205f
Python version: 2.7.15
Qt version: 5.11.1
OCC version: 7.2.0
DeepSOIC
Re: Torus has no Refine property
Postby DeepSOIC » Fri Sep 07, 2018 12:42 am
none of the primitives has it, apparently
Postby chrisb » Fri Sep 07, 2018 12:48 am
I understand. The intended use was probably to start a model with one of the additives, in which case refine is useless. It turns out that they are sensible tio use in the middle as well, the subtractive versions anyway. If it is possible to add this property, I would appreciate it.
DeepSOIC
Postby DeepSOIC » Fri Sep 07, 2018 12:57 am
chrisb wrote: Fri Sep 07, 2018 12:48 am If it is possible to add this property, I would appreciate it.
shouldn't be a problem. There were other missing refines, I would need to search the tracker.
Postby chrisb » Fri Sep 07, 2018 1:01 am
DeepSOIC wrote: Fri Sep 07, 2018 12:57 am
[/quote]Great, and thanks!
NormandC
Postby NormandC » Sat Sep 08, 2018 10:25 pm
You both seem to suffer from some memory loss. :D
issue #3488
Postby chrisb » Sun Sep 09, 2018 9:00 am
Oh oh oh :oops: :oops:
DeepSOIC
Postby DeepSOIC » Mon Sep 10, 2018 6:17 pm
Postby chrisb » Tue Sep 11, 2018 12:35 am
Thanks!
Postby chrisb » Tue Sep 11, 2018 12:13 pm
Tested ok, thanks again.
