I tested this on SW2012 (My company doesn't like to pay for Updates) In this version at least, the $INSUNITS is ignored even if it exists. It's controlled by an input setting in SW, similar to FreeCAD's import scaling preference.wandererfan wrote: ↑Wed Sep 12, 2018 7:46 pm That's all I want for now. If I have that part right, I can make a change so files will be marked metric/mm (since that is what is inside FC).
Then we can try to figure out how to output actual inch measurements.
@rawrpenguinzombies do you know if the software that is being used to import your dxf's has such an option.
As mentioned we can set the scaling at export somehow, but if the importing software respects the $INSUNIT header maybe then it gets messed up?
