How to Trim two Surfaces and apply a Edge Fillet
mark1791
Postby mark1791 » Thu Sep 13, 2018 5:08 am
Hi All
I am trying to see if i can trim two surfaces created using two sketches, then apply a edge Fillet. This is easy in Catia, but trying to do this in FreeCad has me stumped, i can create the two surfaces but trying to trim them is to me next to impossible.
Catia:-
FreeCad:- Get as far as the two surfaces then stumped.
Why this way?, work in Automotive BIW world where we design the panels in Catia GSD and then offset the panel gauge to create solid, so seeing whether i can replicate the design methodology in FreeCad.
Mark
Surface-trim-two-Surfaces-and-apply-edgefillet.FCStd
(15.54 KiB) Downloaded 18 times
freecad-heini-1
Re: How to Trim two Surfaces and apply a Edge Fillet
Postby freecad-heini-1 » Thu Sep 13, 2018 7:47 am
Hi Mark,
face trim at a sketch line can be done with Part split / slice:
Then use boolean fusion.
But I have no idea how to fillet the edge.
Best regards
Wilfried
saso
Postby saso » Thu Sep 13, 2018 7:52 am
For surfacing you will probably want to have a look at some of this addons Curves, nurbs and Silk. They can be installed from Tools -> Addon manager (restart FreeCAD after you install them). Understand that we are still developing FreeCAD, if you stay around the project you can help to push it further :)
https://github.com/tomate44/CurvesWB
https://github.com/microelly2/freecad-nurbs
https://github.com/edwardvmills/Silk
Edit: not exactly what you want but in that direction... A second, updated trimmed version :)
Surface-trim-two-Surfaces-and-apply-edgefillet_sweep_trim.FCStd
(37.09 KiB) Downloaded 13 times
freecad-heini-1
Postby freecad-heini-1 » Thu Sep 13, 2018 10:03 am
Fillets are weak in OpenCascade.
Please have a look how Creo fillet this edge:
DeepSOIC
Postby DeepSOIC » Thu Sep 13, 2018 11:31 am
Done!
trim-connect-fillet.FCStd
(45.74 KiB) Downloaded 24 times
1. Part Section, to get face intersection edge
2. Sketch on the big face. Extend the intersection line.
3. Part Slice the big face with sketch.
4. Part CompoundFilter to get rid of one of the pieces.
5. Part Connect remainings of the big face with small face.
-> the small face is trimmed automatically
6. Fillet.
It's similar to Wilfried's approach. But Part Fuse doesn't connect faces into shells. Connect does. When the shell is properly connected, fillet works.
saso
Postby saso » Thu Sep 13, 2018 11:50 am
I have updated mine a bit more, its manual, but actually gives you quite a lot of options to play with all the corners and make them as you want.
surface.FCStd
(59.99 KiB) Downloaded 16 times
freecad-heini-1
Postby freecad-heini-1 » Thu Sep 13, 2018 11:56 am
Done!
trim-connect-fillet.pngtrim-connect-fillet.FCStd
6. Fillet.
Hi Viktor,
thank you so much for this good instruction. I'm happy to see that every day I can learn more about Freecad.
Connect is the helpful thing here, because it fuses the two faces. Good to know. 8-)
One small improvement. There exists a tool in the Curves-wb to extend the section curve. Location both, lenght 40mm.
Best regards
Wilfried
saso
Postby saso » Thu Sep 13, 2018 12:59 pm
True! :)
saso
Postby saso » Thu Sep 13, 2018 6:08 pm
@freecad-heini-1 did you also use the CompoundFilter after the Slice command in this images or something else? Personally I guess I prefer the Curves -> Trim face tool for this...
But watching your video and playing a bit more around with this it seems to me that Part -> Join, could have another mode (Trim? additionally to the Connect, Embed and Cutout) that would do the direct Trim of both faces, then it would be indeed very much like shown in the above catia example...
ping
What do you think Viktor? :roll:
DeepSOIC
Postby DeepSOIC » Thu Sep 13, 2018 6:34 pm
ping
I don't know. Sounds doable for single faces, but that's a rather special situation. If you want it for something more complex, I don't know how it's going to extend the trim.
