Hiya-
Two-part question here. First, how do I set the distance between both sides of my shape so it is equidistant at all points? I want there to be 6mm between the upper and lower line and curves. It looks like the curves get narrower at one point to me.
Second, when I tried to reolved this 180 deg it says revolved axis intersects sketch.
Thanks, j
OS: Mac OS X
Version: 0.17.13519 (Git)
Branch: (HEAD detached at 1a8b868)
Hash: 1a8b868018f45ea486c0023fdbfeb06febc1fb89
Python version: 2.7.14
Qt version: 5.10.1
OCC version: 7.2.0
Need help with simple revolve
- Awesome Shape.FCStd
- (5.79 KiB) Downloaded 16 times
Re: Need help with simple revolve
Hi, for the first problem give the two arcs a coincident constraint.
When you rotate you get a warning and in the sketch you can see that it intersects while rotating so fix an edge to the Y-axis and that problem is also solved
Thank you kind sir!
- Screen Shot 2018-09-20 at 3.32.24 PM.png (87.83 KiB) Viewed 377 times
