dxf export problem
Czary
dxf export problem
Postby Czary » Mon Oct 01, 2018 3:38 pm
Hello, I've designed guitar amp chassis using FreeCad. I've designed an rectangle, extruded it and used SheetMetal WB to create exact shape of the chassis. All of the circles and openings were made as Draft WB objects, later transfered to pockets using Part Design WB.
Problem appears after dxf export. When I import or open dxf in other CAD, some of the objects become triangles and polygons instead of circles.
https://drive.google.com/open?id=1WRShj ... rxQbrCGnBu
Chassis in FreeCad.
chassis FC.PNG (157.76 KiB) Viewed 346 times
Unfold in SheetMetal WB.
unfold drawing.PNG (70.77 KiB) Viewed 346 times
After dxf export/import.
So far, I've used workaround to replace manually faulty objects in Libre Cad.
Version: 0.17.13528 (Git)
Branch: releases/FreeCAD-0-17
Hash: 5c3f7bf8ec51e2c7187789f7edba71a7aa82a88b
Python version: 2.7.14
OCC version: 7.2.0
Locale: Polish/Poland (pl_PL)
NormandC
Re: dxf export problem
Postby NormandC » Mon Oct 01, 2018 5:11 pm
Hello CZary,
Welcome.
I downloaded and opened your FreeCAD file, and exported the Unfold_Sketch to DXF, see attached. It opens perfectly fine in DraftSight 2018 on Windows 7, and is identical to the original sketch.
POCKET SOLDANO 25 CHASSIS.dxf
(12.5 KiB) Downloaded 13 times
UR_
Postby UR_ » Mon Oct 01, 2018 6:04 pm
... some of the objects become triangles and polygons instead of circles.
That's because some circles are ellipses.
2018-10-01 19_58_07-FreeCAD 0.18.png (7.85 KiB) Viewed 327 times
2018-10-01 19_57_38-FreeCAD 0.18.png (7.99 KiB) Viewed 327 times
UR_
Postby UR_ » Mon Oct 01, 2018 7:22 pm
If you are happy with these ellipses and are willing to update to latest daily build, there is new dxf exporter showing bsplines instead of polylines.
Export is done with TechDrawWB or by python
import Import
obj = App.getDocument("pocket_soldano_25_chassis").getObject("Sketch")
Import.writeDXFObject((obj), u"C:/mypath/my_dxf_file.dxf")
Result will be a dxf file using R14 format without bspline substitution
For details please see here: https://forum.freecadweb.org/viewtopic. ... 10#p251549
