Hi abdullah
abdullah wrote: ↑Sat Nov 10, 2018 6:08 pm
It is merged and in the PPA (thanks sgrogan!). I will appreciate some testing of this trimming functionality.
I did some more testing with the fillet and trim functionallity.
One Issue I found was regarding filleting two arcs. When you click near the center of the arc's notthing happend. I guess this is because the algorythm couldn't found a proper solution for filleting the two arcs. When I click on the right side, it works, but the fillet is placed in the wrong direction and the arcs are shorten way to mutch:
- SketcherFilletArcArcIssue.gif (126.11 KiB) Viewed 339 times
Testfile:
When testing the trim function I noticed that the hyperbola and parabola are not supported. You always get a forbidden/blocked sign when you want select them. Filleting on them works fine in my test cases, except in a similar setup like the issue described above, it could happen that the fillet won't work either between an arc and a parabola. Do you want a Testcase for this too? I hope I can repeat it, it won't always happend, its somehow depending on the geometry
FreeCAD Version:
Version: 0.18.15184 (Git)
Hash: 9e2acc477cc8806f5b7ff13160f40c207a82aa50
Python version: 3.6.6
Qt version: 5.6.2
Locale: German/Switzerland (de_CH)
Kind regards
Roger
