Freecad v. 0.17
Win 7, 64 bit
Branch releases/FreeCad-0-17
Revision number 13522
I've come across a problem and I'm not sure is a problem, I may be misunderstanding here. I'm trying to scale down a sketch (or object for that matter) and have tried the approach listed here:
https://forum.freecadweb.org/viewtopic.php?t=9628
What I'm finding is I can scale the sketch or object up by whole integer factors, but any decimal values I try to place into the X Y Z is ignored, i.e. doesn't appear in the form field at all. Is there a setting or something I'm missing that would allow me to scale my sketch down to a more precise value?
Best, Kevin
Entering float values for scaling of sketch/objects
Re: Entering float values for scaling of sketch/objects
OS: Ubuntu 16.04.5 LTS
Version: 0.17.13541 (Git)
Build type: None
Branch: releases/FreeCAD-0-17
Python version: 2.7.12
its working here.
Your FreeCAD version is out of date, a bug fix release came out about 3 months ago, might fix your issue. Before posting about a bug you might have found, please first check if you have at least the latest of the Release version, and usually test it in the development snap shot as it usually has thousands of bug fixes beyond any Release version.
I assume you are talking about editing the xyz properties of your Draft Clone object? Note that there is a setting in preferences to set how many decimal points can be shown in the gui, also I am using the default Units setting, if you are using some other Units setting then it may have something to do with the issue.
Build type: None
its working here.
And please note that depending on your locale settings you have a dot '.' or a comma ',' as decimal separator.
You're using Draft scale? Sometimes you have to delete some of the 0's before it will let you enter more digits, especially if you have uniform scaling checkbox enabled.
