Sketch rotating problem
klosiu
Postby klosiu » Tue Nov 13, 2018 9:02 am
Hello all!
Recently I started playing with FreeCAD. I tried some tutorials, made few my own models. From time to time it crashes, but I learned to save often, so it's not a big problem. Especially, that I use it for amateur, hobby things.
However, yesterday I faced a problem, that I can't cope with.
Problematic file is attached.
Now, I want to rebuild some part of "szkielet" sketch, so I double click it to enter edit mode. For some reasons, FreeCAD crashes at this step. Sometimes, but very rarely. When I enter edit mode, I want to delete constraints 107 and 108. When I do that, whole drawing tips over. I found out, that's because of constraint to external sketch "otwory" which, for some reason, changes angle to 180 degrees when I remove constraints in another sketch.
What is a reason for that behaviour? Is it wrong to edit sketch after other operations were made (like pad, or pocket)? Maybe I shouldn't attach "otwory" to pad face, which was made from another sketch depending on "otwory"?
Also, is pad supposed to update itself, when I alter sketch it is based on? I added an arc - element 56 in a sketch "szkielet", but as you can see in a file, part based on this sketch didn't reflect the altered sketch.
I use Part Design and Sketcher workbenches only.
This file was originally created in dev version 0.18.15188 on windows 10 x64. Reason for using unstable version is that, I had a similar problem in 0.17, and I wanted to try dev builds, as I thought, that there may be a bug, that's already fixed. I also tried that on another pc with windows 7 x64, with the same results.
prowadnica.FCStd
(192.06 KiB) Downloaded 5 times
HarryGeier
Re: Sketch rotating problem
Postby HarryGeier » Tue Nov 13, 2018 11:29 am
you have strange relationships , in fact not possible relation in the model.
If you look
2018-11-13 12_26_16-FreeCAD.png (53.26 KiB) Viewed 120 times
you can see there are red dependencies that make it totally instable.
I would recommend study the concept of using a MASTER Sketch and rework it accordingly.
Also... some improvements to consider:
5 Circles = 1 constrained with radius/diam and 4 EQUAL ..
similar with the lots of 1 mm lines...
klosiu
Postby klosiu » Tue Nov 13, 2018 12:00 pm
I started with installing graphviz, so I can monitor dependencies.
Then I removed CYlinder, Cone , Pocket and detached otwory sketch from Pad's face.
I understand how szkielet depends on otwory, and Pad depends on szkielet. However, I don't know why otwory still depends on Pad, and why szkielet points to itself.
As of master sketch, otwory was supposed to be one, and szkielet was drawn around it. I then took shortcut, and reuse otwory, to make actual holes. I will redraw it of course. Thanks!
Also, thank you for tip about using equal constrain.
Edit:
I guess I figured it out. It was a real mess. Once again, thank you.
HarryGeier
Postby HarryGeier » Tue Nov 13, 2018 1:10 pm
Fine that you solved your problem,
a MASTER Sketch should only contain geometry that is NOT used to create a feature directly. For all feature sketches you should use references to the master sketch . Look at my videos, where i use master sketches in a variety of ways..
Her i add a simple example file showing 2 ways how to use a master sketch.. I might extend that somehow later or make a video espcially on the different ways of referencing the master sketch
2018-11-13 14_23_36-FreeCAD 0.18.png (131.44 KiB) Viewed 92 times
demo_mastersketch.FCStd
(16.67 KiB) Downloaded 6 times
miniellipse
Postby miniellipse » Tue Nov 13, 2018 9:42 pm
That would be nice. Thanks in advance.
