Hello all!
Recently I started playing with FreeCAD. I tried some tutorials, made few my own models. From time to time it crashes, but I learned to save often, so it's not a big problem. Especially, that I use it for amateur, hobby things.
However, yesterday I faced a problem, that I can't cope with.
Problematic file is attached.
Now, I want to rebuild some part of "szkielet" sketch, so I double click it to enter edit mode. For some reasons, FreeCAD crashes at this step. Sometimes, but very rarely. When I enter edit mode, I want to delete constraints 107 and 108. When I do that, whole drawing tips over. I found out, that's because of constraint to external sketch "otwory" which, for some reason, changes angle to 180 degrees when I remove constraints in another sketch.
What is a reason for that behaviour? Is it wrong to edit sketch after other operations were made (like pad, or pocket)? Maybe I shouldn't attach "otwory" to pad face, which was made from another sketch depending on "otwory"?
Also, is pad supposed to update itself, when I alter sketch it is based on? I added an arc - element 56 in a sketch "szkielet", but as you can see in a file, part based on this sketch didn't reflect the altered sketch.
I use Part Design and Sketcher workbenches only.
This file was originally created in dev version 0.18.15188 on windows 10 x64. Reason for using unstable version is that, I had a similar problem in 0.17, and I wanted to try dev builds, as I thought, that there may be a bug, that's already fixed. I also tried that on another pc with windows 7 x64, with the same results.
Sketch rotating problem
- prowadnica.FCStd
- (192.06 KiB) Downloaded 33 times
- HarryGeier
Re: Sketch rotating problem
you have strange relationships , in fact not possible relation in the model.
If you look you can see there are red dependencies that make it totally instable.
I would recommend study the concept of using a MASTER Sketch and rework it accordingly.
Also... some improvements to consider:
5 Circles = 1 constrained with radius/diam and 4 EQUAL ..
similar with the lots of 1 mm lines...
Kaum macht man´s richtig , gehts´s
My Video Tutorials on Youtube: https://www.youtube.com/channel/UCoe3B ... p8Q/videos
My FreeCAD Stuff on Hidrive: https://my.hidrive.com/share/qr3l1yddy6#$/
I started with installing graphviz, so I can monitor dependencies.
Then I removed CYlinder, Cone , Pocket and detached otwory sketch from Pad's face.
I understand how szkielet depends on otwory, and Pad depends on szkielet. However, I don't know why otwory still depends on Pad, and why szkielet points to itself.
As of master sketch, otwory was supposed to be one, and szkielet was drawn around it. I then took shortcut, and reuse otwory, to make actual holes. I will redraw it of course. Thanks!
Also, thank you for tip about using equal constrain.
Edit:
I guess I figured it out. It was a real mess. Once again, thank you.
Edit:
- HarryGeier
Fine that you solved your problem,
a MASTER Sketch should only contain geometry that is NOT used to create a feature directly. For all feature sketches you should use references to the master sketch . Look at my videos, where i use master sketches in a variety of ways..
Her i add a simple example file showing 2 ways how to use a master sketch.. I might extend that somehow later or make a video espcially on the different ways of referencing the master sketch
- demo_mastersketch.FCStd
- (16.67 KiB) Downloaded 37 times
- miniellipse
That would be nice. Thanks in advance.HarryGeier wrote: ↑Tue Nov 13, 2018 1:10 pm I might extend that somehow later or make a video espcially on the different ways of referencing the master sketch
