THX again for taking care of the Sketcherabdullah wrote: ↑Fri Nov 16, 2018 4:27 am
the missing coincidence detection is part of constrainator:
ActiveSketch.detectMissingPointOnPointConstraints
The open vertex is not there yet.
issue #3693
sketch Validation tool bug
Re: sketch Validation tool bug
I leave you what I have come with in:wmayer wrote: ...
https://github.com/abdullahtahiriyo/Fre ... mmits/3690
If you open the sketch "sk2" in here with it:
https://forum.freecadweb.org/viewtopic. ... 12#p268645
you are notified in the error view of where the problem arises and the user gets a pop-up with a warning, like this: I have problems with some information in the report view due to my ignorance:
https://forum.freecadweb.org/viewtopic. ... 90#p269245
The report view looks like this now:
Exception (Fri Nov 16 18:07:44 2018): Both points are equal In virtual void Part::GeomLineSegment::Restore(Base::XMLReader&) in src/Mod/Part/App/Geometry.cpp:3740
Exception (Fri Nov 16 18:07:44 2018): FreeCAD Exception In virtual void Part::PropertyGeometryList::Restore(Base::XMLReader&) in src/Mod/Part/App/PropertyGeometryList.cpp:218
Property -0.000000000000 of type G was subject to a partial restore.
Exception (Fri Nov 16 18:07:44 2018): FreeCAD Exception In virtual void App::PropertyContainer::Restore(Base::XMLReader&) in src/App/PropertyContainer.cpp:323
Object "Sketch" was subject to a partial restore. As a result geometry may have changed or be incomplete.Exception (Fri Nov 16 18:07:44 2018): FreeCAD Exception In virtual void App::Document::Restore(Base::XMLReader&) in src/App/Document.cpp:1441
All the problems of my previous post remain. It is something like: "hey maybe this functionality is nice to have", but the shoes are too big for me.
I would appreciate your point of view.
The way how to handle all this goes into the right direction. However, there are some issues on the implementation that could be improved. Look at my comments on github, please.
Ok. I have re-implemented it centering on extending the XMLReader.
What I did:
1. Dump the exception mechanism altogether.
2. Extend XMLReader so as to "store" partial restore errors and propagate them upstream. How?
2a. By adding a StatusBits field with bits
enum ReaderStatus {
PartialRestore = 0, // This bit indicates that a partial restore took place somewhere in this Document
PartialRestoreInDocumentObject = 1, // This bit is local to the DocumentObject being read indicating a partial restore therein
PartialRestoreInProperty = 2, // Local to the Property
PartialRestoreInObject = 3 // Local to the object partially restored itself
2c. The bits work in a hierarchical order:
2c.i) Once a partial restore problem arises ALL bits are set.
2c.ii) If the object that requested the restore, at some point is a PropertyList, the PartialRestoreInObject bit is cleared before every object is asked to be restored, checked and if problems arise notify to the report view about the type of object partially restored.
2c.iii) If a class requested the restore of a property (a property container), then before any property is asked to be restored the two lowest rank bits are cleared PartialRestoreInObject and PartialRestoreInProperty before the property is asked to be restored, and the PartialRestoreInProperty is checked, and if problems notify the report view about the Property partially restored.
2c.iv) If a class requested the restore of a DocumentObject, inside fails, the name of the Document object is sent to the Report view. Before every DocumentObject the three lowest rank bits are cleared and checked after the restore.
2c.v) the PartialRestore bit works at Document level and in this trial is never cleared.
3. The Document uses an own status bit to mark that there was a PartialRestore, which can be checked from the GUI and show a pop-up.
The code for review is here:
https://github.com/FreeCAD/FreeCAD/pull/1794
Is not intended for merge, but as a second proof of concept.
Output:
Great work!Ok. I have re-implemented it centering on extending the XMLReader.
Why not? The implementation looks already very good to me. There are only two or three improvements to do which I can do myself after merging the code.Is not intended for merge, but as a second proof of concept.
Thanks again!
I am happy you liked it.wmayer wrote: ↑Mon Nov 19, 2018 1:38 pmGreat work!Ok. I have re-implemented it centering on extending the XMLReader.
Thanks again!
In the original idea, everything worked with exceptions. With the extension of the reader, no exceptions are needed to fix the specific case of the OP.
I have realised that you have added an exception catch block of RestoreError in your additions, I wonder if you have identified a situation where a exception is a better or the only alternative to directly setting the bits on the reader object, or if it is thought just as a way to offer more future flexibility.
Yes, but there was too much forwarding of the exception to the calling instances. My actual idea was to raise the RestoreError only from a property that couldn't be restored any more. Then the PropertyContainer will catch the exception without forwarding it but only sets somewhere a flag that something went wrong. This flag then can be checked in the uppermost instance that started the project load and report it to the user.In the original idea, everything worked with exceptions. With the extension of the reader, no exceptions are needed to fix the specific case of the OP.
Yes, this is for more flexibility in the future as it's up to the author of a property class how he wants to handle errors on restoration (see above). Since we have introduced the new exception type RestoreError an author might use that instead of setting the flags.I have realised that you have added an exception catch block of RestoreError in your additions, I wonder if you have identified a situation where a exception is a better or the only alternative to directly setting the bits on the reader object, or if it is thought just as a way to offer more future flexibility.
Good. Thanks for the insight.wmayer wrote: ↑Tue Nov 20, 2018 1:06 pmYes, this is for more flexibility in the future as it's up to the author of a property class how he wants to handle errors on restoration (see above). Since we have introduced the new exception type RestoreError an author might use that instead of setting the flags.I have realised that you have added an exception catch block of RestoreError in your additions, I wonder if you have identified a situation where a exception is a better or the only alternative to directly setting the bits on the reader object, or if it is thought just as a way to offer more future flexibility.
>>> ActiveSketch.OpenVertices
[(-105.0, 6.0, 0.0), (-105.0, 49.0, 0.0)]
https://github.com/FreeCAD/FreeCAD/pull/1798
