Is there a 3D solid with an elliptical cross section in only two dimensions (i.e., not the doorknob, pill) available in any of the workbenches? I need it to be solid I guess in order to use it as a boolean subtraction.
Or can a cylindrical primitive solid be stretched into an ellipse in this software?
3D column with an elliptical cross section
Re: 3D column with an elliptical cross section
… Clone and Scale:
hammax's suggestion is just one of many.
Alternatives:
Alternatives:
- Create an ellipse primitive (through the Part CreatePrimitives utility) in the Part Workbench and apply a Part Extrude
- Create a Draft Ellipse and create a Part Extrude or even an Arch Structure
- Start a PartDesign Body, create a sketch containing an ellipse, then make a PartDesign Pad
