Ticket #5845 - Changing of the transparency parameter on Radeon GPU problem
Has anyone tried to change the transparency parameter on last FreeCAD build?
Unfortunately, i got some problems with that on my PC with Radeon GPU.
This problem occured only on FreeCAD builds with Qt5.
Link on tracker: https://www.freecadweb.org/tracker/view.php?id=3725
FreeCAD About Info:
Version: 0.18.15299 (Git)
Hash: 5217b245b4f98cf1e3f63ecfe20e379fe4923d80
Python version: 3.6.6
Qt version: 5.6.2
FreeCAD About Info:
Qt version: 5.6.2
- EnginePart.png (121.57 KiB) Viewed 3044 times
Reason: Added GH ticket number to thread title
Re: Changing of the transparency parameter on Radeon GPU problem
Moved to Help forum
Hi mnv, welcome to the forum.
The Radeon cards are known to cause problems. You may try to downgrade the driver: https://forum.freecadweb.org/viewtopic.php?f=3&t=30573.
Unfortunately, this problem is also occurred on old driver version.
I think this problem in porting to Qt5, because old FreeCAD versions and builded by hand FreeCAD version with Qt4 works fine.
So essentially it may be an upstream Qt5 issue?
Re: Ticket #3725 - Changing of the transparency parameter on Radeon GPU problem
bumpity bump
Looks Ok to me:
OS: Windows 10 Version 2009
Version: 0.20.27221 (Git)
Hash: 4a18442e049a522ef46278493010d9320925bd0d
Python version: 3.8.8
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Locale: Bulgarian/Bulgaria (bg_BG)
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
I think this was determined ultimately to be an issue with COIN 4.0.0a (a being alpha?)
Re: Ticket #5845 - Changing of the transparency parameter on Radeon GPU problem
TheMarkster wrote: ↑Wed Jan 26, 2022 5:15 pm I think this was determined ultimately to be an issue with COIN 4.0.0a (a being alpha?)
@mnv do you mind following up?
I'm closing issue #5845 for now. If the issue persists, you can ask for it to be re-opened
