.emn file opening
mindflow
.emn file opening
Postby mindflow » Tue Dec 18, 2018 6:50 am
Hi Everyone,
I could no able to open .emn or .brd files in freecad.
Is there any setting to that ?
thanks,
openBrain
Re: .emn file opening
Postby openBrain » Tue Dec 18, 2018 12:21 pm
Hi Everyone,
thanks,
.EMN is the standard extension for IDF board description. It should nicely open in FreeCAD. I never had any problem with it.
About .BRD, I don't think this format can be directly open by FreeCAD.
Could you detail the issue or provide the .EMN file ?
BR
mindflow
Postby mindflow » Tue Dec 18, 2018 12:47 pm
Can you send mail address ?
I will send the .emn file
thanks,
MS
openBrain
Postby openBrain » Tue Dec 18, 2018 1:59 pm
thanks,
MS
Better use the attachment function of reply posting ???
mindflow
Postby mindflow » Wed Dec 19, 2018 5:24 am
I tried it, but can't able to attach the .emn file.
If you send the mail address I will do it immediately.
thanks,
MS
mindflow
Postby mindflow » Wed Dec 19, 2018 5:33 am
It shows "INVALID EXTENSION",
Please help...
MS
easyw-fc
Postby easyw-fc » Wed Dec 19, 2018 6:36 am
Please help...
MS
Zip it and attach the zip file.
mindflow
Postby mindflow » Wed Dec 19, 2018 9:26 am
Thanks
I have attached it. Please check
MS
.emn.zip
.emn file
(29.55 KiB) Downloaded 3 times
easyw-fc
Postby easyw-fc » Wed Dec 19, 2018 12:01 pm
Thanks
no issue if you don't use FC with Py3/Qt5 build...
it is fine i.e. with FC Version: 0.18.15396 (Git)
NB you need to create a new document and then import the 'emn' file
the emn is exported from Allegro pcb designer... I don't think there is a direct importer for FC ATM
mindflow
Postby mindflow » Wed Dec 19, 2018 12:16 pm
I'm using FC 0.17.
What shoud I do ?
Thanks,
MS
