Sweep along path created by 3D-Parametric-Macro
Hello everyone
I just started using FreeCAD and I want to model some wires for a FEM simulation. In order to do so, I need to sweep a rectangular sketch along an elliptical trajectory (or path) (see also the two screenshots in the attachment).
The problem is that when I try to use the "utility to sweep" under the "part workbench" I am unable to choose the path I created for the sweep operation. When I click on the "Sweep Path" button in the sweep menu, I can´t choose the elliptical path I created using the "3D Parametric Curve" Macro.
Does anyone have ideas on how to resolve this issue?
I attached the project file.
Thanks!
Thanks!
- Screenshot from 2018-12-20 16-40-10.png (137.99 KiB) Viewed 2031 times
- Screenshot from 2018-12-20 16-38-11.png (68.02 KiB) Viewed 2031 times
- test.fcstd
- (81.2 KiB) Downloaded 50 times
Re: Sweep along path created by 3D-Parametric-Macro
You can create your helix from the part WB create primitives option. That should work....
HTH Steve.
HTH Steve.
I was able to select the DWire as sweep path. I think I know what's happening: the DWire actually consists of a great number of short line segments. If you see the "interdict" sign when trying to pick the path in the 3D view, the pointer is probably over a vertex. Simply zoom in (a lot) to be able to select an edge. Then, select it a second time to select the whole path.
But I agree with Bance, it would be much better to use the already existing Part Helix that you can create from the Part CreatePrimitives utility.
When making the sweep, don't forget to check the "Frenet" option.
Thanks for your replies, I could create the shape I wanted using the "Create Primitives" utility.NormandC wrote: ↑Thu Dec 20, 2018 6:12 pm I was able to select the DWire as sweep path. I think I know what's happening: the DWire actually consists of a great number of short line segments. If you see the "interdict" sign when trying to pick the path in the 3D view, the pointer is probably over a vertex. Simply zoom in (a lot) to be able to select an edge. Then, select it a second time to select the whole path.
However, I'm curious about the option "Frenet". I´m referring to https://www.freecadweb.org/wiki/images/ ... t-comp.png. It seems like the "Frenet" option doesn´t work for a path which consists of short, successive straight lines?
Another question: How can I "connect" the two coils in the file in the attachment via two Bézier-Curves?
- test.fcstd
- (15.87 KiB) Downloaded 49 times
- connecting_coils.png (102.41 KiB) Viewed 1996 times
I'm not sure why. Maybe DeepSOIC (a FreeCAD dev and the one who created the image you linked) would know more.
DeepSOIC wrote:ping
I'm not sure what you mean. To me they appear to be already connected.
Probably a better choice would be using this tool:
from "Curves" workbench.
Can be installed using addon manager
Here are some nice properties available to play with
file:
done with:OS: Windows 10
Version: 0.18.15481 (Git)
Hash: 763b5c362fe4b98dca858f86f5d1353075224651
Python version: 3.6.6
Qt version: 5.6.2
Develop a Sweep Trajectory in 3D Space
I am working on an exercise of an exhaust pipe. It follows a curved path in 3 dimensional space.
To create the 70mm curve, all that I need is an arc. The other curve is made up of two 60mm arcs that are
tangential.
Then I found that I could not create a surface that has a boundary edge that is made up of two arcs.
I know that there are several tools that supposedly make a single bspline from several arcs but I am not having
much luck getting them to work and am not at all sure that they do what I think that I want.
So, am I going down a path that dead ends? Trying to make a BSpline curve that has the required radii doesn't'
seem likely to work very well, either. What am I missing? Is there a better way to make this kind of trajectory?
Or will FreeCAD not even sweep an Additive Pipe along a trajectory like this?
GA
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
To create the path it looks like I should be able to create two Surfaces and take their intersection to get the path.To create the 70mm curve, all that I need is an arc. The other curve is made up of two 60mm arcs that are
tangential.
GA
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
I don't think this is exactly right, but it's a start. It's hard for me to see the dimensions in the image. That's my excuse and I'm sticking to it.
To make the spline I made 2 sketches, one on the xz and one on the yz plane. Extruded them symmetrically in Part workbench to create curved faces, then cut one face from the other to find the intersection. I made the green subshapebinder from the intersection edge.
- exercise_742.FCStd
- (159.68 KiB) Downloaded 31 times
- Snip macro screenshot-1d8d8d.png (54.73 KiB) Viewed 1255 times
TheMarkster,
I looked at your example and read through your process. Thank you for the suggestions.
This is leading me into areas that I have not (yet) worked with.
I experimented with something very close to what you described:
All done in one Body:
Two Sketches for the two curves on different planes.
Extrude both Sketches symmetrically (in Part)
Cut (Cutout for Object) (in Part) to expose the intersection.
New Shape Binder (Blue) (in Part Design), select the Cut (intersection) line.
Additive Pipe
And it looked quite good. But, alas, I was just throwing some arcs into the model.
I went back and tried to make it based on the dimensions that were given in the exercise.
Well, I got something. Clearly I have some reading and experimenting to do.
Again, thank you. I will be making some more tries to understand this over the next several days.
GA
Additive Pipe
GA
- 742.png (27.71 KiB) Viewed 1164 times
