DXF file scale setting
I have completed modelling one part afterwards, I have converted it into " Shape2D View".
I exported that file as .dxf and saved.
When I am opening that file and checking dimensions, all are 25.4 times more than that of original one.
Please help me with it.
Thanks,
MS
Thanks,
MS
Re: DXF FILE SCALE SETTING
This is clearly the ratio between mm and in (1 inch = 25.4 millimeters).
Check the units you use for both original drawing and DXF import.
It's a common trap as DXF doesn't manage units.
In any case, you can solve your problem with the ratio setting in the Import-Export preferences of FreeCAD.
Original drawing is in mm.
I'm imported it in e-drawing software and opened.
There it is multiplies 25.4 times.
I have checked any unit options in it. But couldn't get any.
Any suggestions ?
Thanks,
MS
Any suggestions ?
Thanks,
MS
I guess e-drawing considers by default DXF to be encoded in inches.
I don't know a lot about e-drawing. Perhaps there is an option to tell it the default unit to be used.
Are the dimensions correct if you import your DXF back to FC, or in another tool as LibreCAD ?
I have imported back to FC & dimensions are same.
Same as original or as in e-drawing ?
Could you provide both FCstd and DXF files ?
Hi ,
I have attached .dxf file.
FC file too big,couldn't attach it.
- ETHZ2-2G-O62-01 BOARD-TOP SIDE.dxf
- (41.35 KiB) Downloaded 213 times
- ETHZ2-2G-O62-01 BOARD-Bottom side.dxf
- (439.17 KiB) Downloaded 172 times
Without the FC file and any information, I have nothing to compare to...
Anyway, both in FC and in LibreCAD, the surrounding square shows a side dimension of 65 mm. Is that correct ?
Yorik, as DXF importer expert ( ), I got the following bug with the new importer (while old python importer works well) with the top side file provided above by mindflow : Maybe you can confirm and open a bug tracker if needed.yorik wrote: Ping
OS: Ubuntu 18.04.1 LTS
Version: 0.18.15521 (Git)
Hash: 6cdeab9c1469a41f24ae5e8fa9091c9bdfbb90db
Python version: 2.7.15rc1
Locale: French/France (fr_FR)
- wandererfan
The Dxf spec is dimension-less until version R2000/AC1015. The FreeCAD legacy exporter only does R12 and the newer exporter only does R12 and R14.
The app that reads the Dxf file (e-drawing) is supposed to map the dimension-less input into the desired units, but some (many? most?) apps just interpret incoming dimensions as inches.
