Edge routing / filleting - custom profile?
Brutha
Postby Brutha » Tue Jan 08, 2019 12:42 pm
Hi All,
Quick question, does anyone know of any functionality where I can give a custom profile for a fillet? For example, beading as shown below, from the Wikipedia page here: https://en.wikipedia.org/wiki/Router_(woodworking)
Screenshot 2019-01-08 at 12.34.34.png (9.86 KiB) Viewed 219 times
It was discussed before here https://forum.freecadweb.org/viewtopic. ... ing#p53954 - wondered if anyone had found / done something since then?
Cheers
Brutha
Re: Edge routing / filleting - custom profile?
Postby chrisb » Tue Jan 08, 2019 2:33 pm
Nothing has been done to this since 2014. You still have to DIY, by using pockets or subtractive sweeps
babaroga
Location: Banja Luka, Republic of Srpska, Bosnia and Herzegovina
Postby babaroga » Tue Jan 08, 2019 3:54 pm
You can do something like this:
1. Open PartDesign WB
2. Create new Body
3. Create sketch and make a pad out of it. It will be eg. cabinet door.
4. Make another sketch with profile you want to make on door. Sketch plane is suppose to be perpendicular to plane you created pad sketch in step 3.
It should have geometry of your milling tool. Position sketch like you would position router bit.
5. Select sketch with profile in feature tree and click Subtractive sweep.
screen 3.png (21.17 KiB) Viewed 191 times
6. Now, in "Corner transition" select right corner, then press button "Add edge" and select edge on Pad where you placed your profile sketch. You will get something like this:
screen 4.png (96.68 KiB) Viewed 191 times
Then press "Add edge" and select next edge on pad. Repeat operation for all remaining edges.
7. You will get something like this:
screen 5.png (104.55 KiB) Viewed 191 times
babaroga
Postby babaroga » Tue Jan 08, 2019 3:56 pm
You can do same in also in the middle of Pad and get this:
screen 6.png (138.1 KiB) Viewed 191 times
Profiles.FCStd
(61.3 KiB) Downloaded 7 times
Brutha
Postby Brutha » Tue Jan 08, 2019 8:03 pm
@Chris - thanks!
@Babaroga - great, will give that a try, thanks very much!
