Selection view, search activation?
Running a newish build of v0.18, 47fd9d3
One is supposed to be able to search using the Selection View.
I can type into the search box, but it's not clear to me how to cause the search to actually happen.
Is it supposed to happen on the fly as one is typing?
If so, it doesn't work for me.
If I select something by clicking in the 3D view, I see the objects listed.
e.g.:
Clicking on the face of a cube shows:
Unnamed1.Box.Face3 (Cube)
But typing "Box" in the search field yields nothing (adding <enter> or <tab> has no visible affect)
User error?
Bug in v0.18 (regression?)
e.g.:
User error?
Re: Selection view, search activation?
It works in both of the versions shown below by incremental search, i.e. searching while typing.
For posts assuming a regression you should include your full FreeCAD info (we don't even know which OS you use) and preferably that of a version where it still worked, e.g. 0.17.
OS: macOS 10.13
Version: 0.18.15525 (Git)
Hash: 1a7d3d9a37fe43468c8ac84590c1db53e2b2000a
Python version: 3.6.7
Qt version: 5.6.2
OS: Ubuntu 16.04.5 LTS
Version: 0.18.15611 (Git)
Hash: 64a94ae0f7c60fc981086fe157150a9c0dca29c6
Python version: 2.7.12
OS: macOS 10.13
Qt version: 5.6.2
Thanks.chrisb wrote: ↑Sat Jan 12, 2019 7:10 am It works in both of the versions shown below by incremental search, i.e. searching while typing.
Unfortunately, I don't have a previous version where I know it worked; this is the first time I've attempted to use it.
OS: FreeBSD 11.2-RELEASE-p4 amd64
Version: 0.18
Revision number: a14af0f
Build type: development port
Hash: a14af0f...
Python version: 2.7.15
Coin version: not sure how to interpret the libs:
- libCoin.so.60.1.3
- libCoinMP.so.1.8.3
- libCoinUtils.so.3.10.10
Locale: default, en_US
Just backed out and installed:
Version: 0.17
Revision number: 13541
Build type: standard port
Branch: not sure, git fetch from hash below
Hash: g9948ee4f1
- libCoin.so.60.1.3
The 0.17 version functions minimally:
If I go to Part WB, create a cube.
Select one face, I see in the selection view:
Unnamed.Box.Face3 (Cube)
If I type in the search box "B" I see:
Unnamed.Box (Cube)
If I type in "Bo" I see nothing.
If I select one edge, I see:
Unnamed.Box.Edge10 (Cube)
If I type in "E" I see nothing
Correction, both versions:
Interestingly, typing the second letter from "Un" or "Bo" makes the "Unnamed.Box (Cube)" disappear, but "cube" keeps it found for all letters; it disappears when "cube)" is entered.
It also shows up for "e", but not "ed"
No other letters work.
If I type in "E" I see:
Unnamed.Box (Cube)
The IMPORTANT forum guide linked above tells you how to add your FreeCAD info in an extremely easy way.
Thanks, unfortunately reading it doesn't make me remember it :-(. I didn't realize hitting the copy button captured more than the dialog displays. It might be useful for the dialog to say so.
The info copied there is mostly right, but not completely:
OS: UNIX Correct, but not as useful as FreeBSD 11.2-RELEASE-p4 amd64
Version: 0.18.a14af0f
Build type: Release It is not a release build, either in the process used to build it or the code snapshot
Coin version: 3.1.3 If some magic maps 60.1.3, 1.8.3, and 3.10.10 to 3.1.3 so be it :-)
Locale: C/Default (C)
In Python console you see only things changing the model - and even not all of them.
In Preferences you redirect output to Report view, but it shows nothing during searching.
If you start FreeCAD with the additional parameter -l (small letter L) you get additional output in a logfile in your FreeCAD directory. You can try if it gives you more information, I don't know.
I think it is good the way it is, because everthing I want to see is shown in Selection view's result window. If it's found it shows there, if not it does not. What else should it do to flood the outpout windows?
In earlier versions, as soon as you typed letters, the matching objects would be selected. But this clogged a lot on large models, so in 0.18, you have to press Enter to actually select the matching results.
Maybe we need to also add a button?
I don't think so. To me it is very intuitive. While typing the list is created, if I want to select one of the items I use the mouse. Very common behaviour nowadays.
Can you explain the behavior you see for the following:
Create a cube using the part WB
In the search box, which should initially be empty:
Type 'B'
I see:
Unnamed.Box (Cube)
Add 'o':
The "Unnamed.Box (Cube)" disappears
Add <enter>
No change; nothing visible
If <enter> is now required, then nothing should show up with the initial "B".
If <enter> is required, I think a button would be helpful; I think Macs use a magnifying glass in the end of the search field, but not sure.
