[Resolved - sorta] Display quirk in Windows Conda-Python3-Qt5 version
easyw-fc
Re: Display quirk in Windows Conda-Python3-Qt5 version
Postby easyw-fc » Tue Jan 15, 2019 11:45 am
Syres wrote:
Tue Jan 15, 2019 10:56 am
Not wanting to put a spanner in the works but am I the only Windows user who does not experience this display problem?
For me it is displayed fine too:
NVidia GPU GeForce GTX950
FreeCAD_0.18.15456_Conda_Py3QT5-WinVS2015_x64.7z
Version: 0.18.15611 (Git)
Hash: 64a94ae0f7c60fc981086fe157150a9c0dca29c6
Python version: 3.6.6
Qt version: 5.6.2
Syres
Postby Syres » Tue Jan 15, 2019 11:50 am
A lowly Nvidia GeForce GTX 670 but found it's extremely 'compliant' with a variety of software.
looo
Postby looo » Tue Jan 15, 2019 1:22 pm
So a graphics-card issue... I will try to update drivers. Maybe this helps.
Maybe someone else can try to reproduce this graphics-problem. To reproduce create a cube and mesh it with FEM-Wb. Selecting one of the axis-parallel views (with an orthogonal camera) gives the following result for me. It would be interesting if there are versions which show the edges.
mesh
Bildschirmfoto von 2019-01-15 14-09-33.png (10.36 KiB) Viewed 495 times
axis-parallel-view
Bildschirmfoto von 2019-01-15 14-09-40.png (4.66 KiB) Viewed 495 times
easyw-fc
Postby easyw-fc » Tue Jan 15, 2019 2:57 pm
would you mind to attach the file?
I cannot mesh the cube in the way you did...
DeepSOIC
Postby DeepSOIC » Tue Jan 15, 2019 3:02 pm
Yes, it's related to graphics driver. My laptop has switchable GPU (intel hd graphics 620 or geforce 940MX), and if I run FC on nvidia, the edges are visible as they should be.
Strangely, the good old py2-qt4 version is not affected.
GeneFC
Postby GeneFC » Tue Jan 15, 2019 3:50 pm
In case it is relevant, details on my graphics.
Processor: Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz
Processor Speed: 3392 MHz
Processor Graphics in Use: Intel(R) HD Graphics 4600
Shader Version: 5.0
OpenGL* Version: 4.3
OpenCL* Version: 1.2
* Microsoft DirectX* *
Runtime Version: 11.0
Hardware-Supported Version: 11.0
Gene
looo
Postby looo » Tue Jan 15, 2019 5:17 pm
cube.FCStd
(4.73 KiB) Downloaded 11 times
would be nice to know which flags the py2-qt4 coin3d-build used.
GeneFC
Re: [Resolved - sorta] Display quirk in Windows Conda-Python3-Qt5 version
Postby GeneFC » Wed Jan 16, 2019 2:59 pm
Based on comments in this topic I went back and started trying older graphics drivers. I finally found one more than three years old that did not show the missing line problem. The driver has exactly the same version of OpenGL (4.3), and all other reported components (Open CL, DirectX, etc.) have the same versions. There obviously are some internal changes, but I have no idea what they would be.
I do not use this computer for any intensive graphics, such as gaming, so the older driver is fine.
It is potentially troubling that FreeCAD seems to have more and more problems with newer video cards and newer drivers. The video folks are always aiming for more speed and features. Newer computers and newer video cards may be unable to work with FreeCAD in the future.
I know this is a bit doomsday, but something to keep in mind.
One hint to what might be happening was observed when I tried making the object transparent. When I changed the transparency to as little as 1% the missing line popped into view. Perhaps something to do with rendering order for transparent objects versus rendering order for solid objects.
Gene
PrzemoF
Postby PrzemoF » Wed Jan 16, 2019 3:04 pm
Can you post the driver version if someone else needs it?
GeneFC
Postby GeneFC » Wed Jan 16, 2019 8:15 pm
The working graphics package version is:
Intel Graphics Driver for Windows 7 & 8.1 [15.36.28.4332]
The installed driver is:
Driver Version: 10.18.14.4332
The release date is 2015-12-11.
This version is specific to a processor family (4th generation Core), onboard graphics system (HD 4600), and OS (Windows 7). I do not know how widely it may apply to any variations.
I did not do an exhaustive search. I just kept trying backward in time until I found one that worked.
Gene
