Hi
I use FreeCAD 0.17 on Linux
I've created a simple part - an empty cylinder with a base. When I export this (I want to import in Slic3r) the cylinder is almost filled. May I ask for help? I attached an original and an exported part.
BR
Michal
Problem with export from FreeCAD
- freecad-model.png (18.49 KiB) Viewed 391 times
- imported-stl.png (4.41 KiB) Viewed 392 times
Re: Problem with export from FreeCAD
If you selected only the last feature(PartDesign WB)/last operation (Part WB) and get this result, then upload your model.
Thank you very much for a suggestion. I exported from "Part" not from "Part Design". If I switch to "Part Design" and export everything is ok
It's not the Workbench from which you export, it's the selection in the tree, and how you built the model.
For PartDesign models I always export the Body and I select nothing else.
