TechDraw and Drawing Dimensioning construction angles
steveKimpton
Postby steveKimpton » Thu Jan 24, 2019 4:45 pm
If I create an object where the holes line up along a construction line set at a particular angle, I can't see a way to convey this information in the tech draw or drawing dimensioning workbenches - see attached test object.
Of course I could use the x and y dimensions but the purpose of the tech draw workbench is to give helpful information to the person who has to make the object.
Any ideas?
testangular.FCStd
(75.51 KiB) Downloaded 7 times
openBrain
Re: TechDraw and Drawing Dimensioning construction angles
Postby openBrain » Thu Jan 24, 2019 6:24 pm
I'm sorry I'm not gonna give you a solution. But tell this way of locating seems dangerous to me.
First X/Y dimensioning is simpler (better ?) both for making the part and for controling it.
But also defining angle between hole center line and edge line is not enough : it doesn't correctly locate the holes. ;)
All in all, IMHO you should use a standard X/Y dimensioning reatively to reference faces. :)
Postby chrisb » Thu Jan 24, 2019 11:40 pm
You can create another sketch which gets the angle via external geometry. You can add this sketch to your TechDraw document.
wandererfan
Postby wandererfan » Fri Jan 25, 2019 1:43 am
If I create an object where the holes line up along a construction line set at a particular angle, I can't see a way to convey this information in the tech draw ,,,,
TechDraw_Dimension_Angle3Pt
meme2704
Postby meme2704 » Fri Jan 25, 2019 10:25 am
Hi
My solution (home made)
Do a new sketch containing the 2 sides of the angle,
place it on the page
mark this angle in his page
Edit
My mouse has been faster than my shadow, there is indeed a tool "angle by 3 points
Sorry :oops:
steveKimpton
Postby steveKimpton » Tue Feb 19, 2019 10:46 am
Thanks meme2704. Sorry for the delay in getting back to this. Where is the angle by 3 points tool? I've failed to find it in either Tech Draw or Drawing Dimensioning.
Postby chrisb » Tue Feb 19, 2019 12:27 pm
It is available in 0.18 only.
