In my previous post I already mentioned changing the orientation of the sketch.
DXF Export Not Working
Re: DXF Export Not Working
Yes, true and thanks
Thank you all for your answers, this was very helpful and I was able to fix the problem by changing the Map Mode of the sketch and attach it back to the XZ plane, after which the dxf exported correctly, provided the "Project exported objects along current view direction" was set, without which the central triangle would not be present in the export.
openBrain, could you explain what you mean by Legacy Importer? For me it worked properly by doing File->Import and selecting the dxf file.
I checked the original sketch (before deleting the spreadsheet and any other components) and the constraints were exactly the same as after deleting the spreadsheet (i.e. coincidence and symmetry constraints referencing the Spreadsheet). I think this might be a bug.GeneFC wrote: ↑Thu Jan 24, 2019 8:49 pmMy typical response to this sort of question is that when improper references are made or other errors occur all bets are off. There can be various strange consequences. In this case probably some indexing error that tried to apply the missing spreadsheet constraints to the wrong elements in the sketcher.
If this is somehow a consistent pattern then it might be a bug. In the present case it is probably nothing.
Sure. In the DXF importing preferences of FC, you can choose to use the new importer, or the legacy one. In my (limited experience), at that time the new importer regularly fails to import correctly, and I have to keep the legacy importer.
how related to issue #4133 is this thread ?
Migrated to GH issue #5990
