Problem importing Step (.stp) - File
NormandC
Re: Problem importing Step (.stp) - File
Postby NormandC » Sat Feb 02, 2019 4:14 pm
Those calls refer to libraries from the OCC geometric kernel. I'm not sure there's anything that can be done here. It's possible that the original STEP file is faulty. It may be surprising, but some commercial CAD packages have very poor STEP export capability.
You could try importing the STEP file in another CAD program or viewer. For example there is CAD Assistant, a viewer made by Open Cascade (maker of the OCC kernel that FreeCAD uses). There's a Windows version. https://www.opencascade.com/content/cad-assistant
Site Admin
Postby wmayer » Tue Feb 12, 2019 8:14 pm
<type 'exceptions.RuntimeError'>: Access violation
The Access violation message usually is an indication that a segmentation fault occurred somewhere. Because on Windows FreeCAD is built with the SEH option the application in many cases survive the segmentation fault. There is a good chance that the bug is with OCCT 7.2.
Above you said that it imports fine with CAD Assistant which is also based on OCCT. Can you figure out on which OCCT version your installation of CAD Assistant depends on?
