Nurbs and Silk errors
Stou
Postby Stou » Mon Jan 28, 2019 2:10 pm
I installed Nurbs and Silk via Addon Manager without any error but when I tried to used it, I have errors. It look like there's some modules and variables missing.
Nurbs errors:
Running the Python command 'Nurbs_createsketchspline' failed:
File "<string>", line 271, in Activated
File "C:\Users\stou9\AppData\Roaming\FreeCAD\Mod\nurbs\nurbswb\createsketchspline.py", line 9, in <module>
from scipy.signal import argrelextrema
No module named scipy.signalRunning the Python command 'Nurbs_createsketchspline' failed:
Do I need to install scipy.signal package manually to get it work?
Silk errors:
Running the Python command 'ControlPoly4' failed:
File "C:\Users\stou9\AppData\Roaming\FreeCAD\Mod\Silk\ControlPoly4.py", line 42, in Activated
print mode
local variable 'mode' referenced before assignment
Do I need to set some variables somewhere?
microelly2
Re: Nerbs and Silk errors
Postby microelly2 » Mon Jan 28, 2019 2:56 pm
Yes the complete scipy package is required for a lot of the methods in nurbs wb.
Stou
Postby Stou » Mon Jan 28, 2019 6:37 pm
Thanks microelly2!
I installed WinPython 3.6.7.0 which included scipy. In GitHub, I downloaded and installed Winpython64-3.7.1.0.exe (461mb) but there's also Winpython64-3.7.1.0Zero.exe (27mb).
There's no info on what is the 3.7.1.0Zero package. Any idea? Do I need to install the Zero package too?
But only with the one I installed, it seem to work fine. But I didn't do many things with it for now, I have to read about Nerbs and Silk to lear it a little bit.
Stou
Postby Stou » Mon Jan 28, 2019 6:46 pm
I talked to fast, I still have problem with variables in Silk.
local variable 'mode' referenced befor assignmentHide main window
microelly2
Postby microelly2 » Mon Jan 28, 2019 7:22 pm
emills2 wrote:
Fri May 25, 2018 6:29 am
ping
Stou
Postby Stou » Mon Jan 28, 2019 8:23 pm
ping
??? I don't understand!
microelly2
Postby microelly2 » Tue Jan 29, 2019 10:09 am
this is a common trick to send emills a notification to read this thread.
Stou
Postby Stou » Tue Jan 29, 2019 11:03 am
Ok, you sent a ping to emills! :lol:
Postby Kunda1 » Tue Jan 29, 2019 1:02 pm
Hey @Stou would you be kind enough to edit the title of the first post of this thread from Nerbs to Nurbs please? Thanks.
Stou
Re: Nurbs and Silk errors
Postby Stou » Tue Jan 29, 2019 2:25 pm
Done! Thanks, I didn't noticed that typo.
