Nurbs and Silk errors
emills2
Re: Nurbs and Silk errors
Postby emills2 » Wed Jan 30, 2019 5:36 pm
Stou wrote:
Mon Jan 28, 2019 2:10 pm
Silk errors:
Running the Python command 'ControlPoly4' failed:
File "C:\Users\stou9\AppData\Roaming\FreeCAD\Mod\Silk\ControlPoly4.py", line 42, in Activated
print mode
local variable 'mode' referenced before assignment
Do I need to set some variables somewhere?
if 'mode' wasn't assigned, that means your selection was not recognized. In Silk you always have to select your input before hitting the function.
here is an old tutorial for basics
https://github.com/edwardvmills/NURBSli ... cCurve4.md
just ignore the parts that tell you to change element colors. that is automatic now. EDIT: also ignore setup stuff. SIlk as a workbench takes care of that.
have to jet right now, but i'll come back to help if the tutorial above doesn't do the trick
Syres
Postby Syres » Wed Jan 30, 2019 6:12 pm
As someone who's completed the tutorial series in the past without any issues (very good step-by-step documents), I might be able to narrow down what's going on. I don't believe the OP stated the full FreeCAD info so maybe that's why it might not have been clear that it was a Python 3 error (my incorrect assumption).
Using :
OS: Windows 7
Version: 0.18.15697 (Git)
Hash: dedaa807629ab25cf32977d30bf7610f1346aff7
Python version: 2.7.14
OCC version: 7.2.0
all the first steps appear to work as expected therefore I would envisage all is well with Py2Qt4 builds but, using :
OS: Windows 7
Python version: 3.6.6
Qt version: 5.6.2
just changing to the Silk workbench (not clicking any buttons) causes this error:
Stou
Postby Stou » Thu Jan 31, 2019 2:54 am
I'll have a look at the tutorial tomorrow, I will let you know after the tutorial, thanks!
emills2
Postby emills2 » Thu Jan 31, 2019 8:25 pm
just fyi, i checked Silk workbench on
Version: 0.18.15748 (Git)
Hash: 13622cd0b80103ea22969f53df42253038083e40
OCC version: 7.2.0
And the existing test model load and updates correctly. in the past, i have had to play catch up with the dev branch. on FreeCAD 0.17 with python 2.7 should be pretty solid.
Stou
Postby Stou » Sat Feb 02, 2019 1:08 am
I did the first Nurbs tutorial and it work fine. After that, just to see if I have the same error as Syres, I switch to Silk WB. I didn't had any error.
Next, I'll do the tutorial 0.02!
Syres
Postby Syres » Sat Feb 02, 2019 11:20 am
Py3 Fixes
I've had a pretty successful attempt at making the Silk Wb both Py2 and Py3 compatible but having been in and out of different builds only on Windows 7, it would be wise if someone else was willing to extract the attached zip file and copy over the corresponding Wb files. For those who are unaware, these are held in DriveLetter:\Users\userid\AppData\Roaming\FreeCAD\Mod\Silk
If these changes cause any major problems then you just need to use the Install/Update button in AddOn Manager to put the workbench back to normal and restart FreeCAD.
My Py3 testing was done using:
OS: Windows 7
Qt version: 5.6.2
and my retro Py2 testing was done using:
OS: Windows 7
Version: 0.17.13509 (Git)
Branch: releases/FreeCAD-0-17
Hash: 0258808ccb6ba3bd5ea9312f79cd023f1a8671b7
OCC version: 7.2.0
Silk_Py3.zip
(36.12 KiB) Downloaded 20 times
