if 'mode' wasn't assigned, that means your selection was not recognized. In Silk you always have to select your input before hitting the function.Stou wrote: ↑Mon Jan 28, 2019 2:10 pm Silk errors:
Running the Python command 'ControlPoly4' failed:
File "C:\Users\stou9\AppData\Roaming\FreeCAD\Mod\Silk\ControlPoly4.py", line 42, in Activated
print mode
local variable 'mode' referenced before assignment
Do I need to set some variables somewhere?
here is an old tutorial for basics
https://github.com/edwardvmills/NURBSli ... cCurve4.md
just ignore the parts that tell you to change element colors. that is automatic now. EDIT: also ignore setup stuff. SIlk as a workbench takes care of that.
have to jet right now, but i'll come back to help if the tutorial above doesn't do the trick
