Create two pads on the side of a cylinder
arcol
Postby arcol » Wed Jan 30, 2019 10:08 am
I'd like to create this drawing:
Thanks to tripus help on this thread:
https://forum.freecadweb.org/viewtopic. ... 53#p283276
I succeed to create the bottom pad, but creating the top pad, it does not show up:
I used the exact same method for both pads as tripus suggested.
PartDesign AdditiveCylinder feature was added, Sketcher CreateCircle can be attached on XZ or YZ plane and can be used as a basis for PartDesign Pad feature
Here is the freecad file:
water_tank_wip.FCStd
(46.83 KiB) Downloaded 15 times
What do I miss? Why the top pad does not show up?
My Freecad version for reference (ubuntu freecad-daily for 18.04):
OS: Ubuntu 18.04 LTS
Version: 0.18.15713 (Git)
Hash: 93dd00cc3953416bf46fb0a5b7b3c6397df6e4d0
Python version: 2.7.15rc1
Qt version: 5.9.5
Locale: Hungarian/Hungary (hu_HU)
HarryGeier
Re: Create two pads on the side of a cylinder
Postby HarryGeier » Wed Jan 30, 2019 11:12 am
HI,
pad in reverse direction, then it shows up.
The Circle´s orientation is reversed, thus the positive normal pointws inwards.
I tried to explain by using the new LCS , but yur design is weird, FC tells me the sketches do not belong to the active Body...
I would not recommend starting a design based on a cylinder or other primitive object, start with a sketch and PAD
harry
Kaum macht man´s richtig , gehts´s
My Video Tutorials on Youtube: https://www.youtube.com/channel/UCoe3B ... p8Q/videos
My FreeCAD Stuff on Hidrive: https://my.hidrive.com/share/qr3l1yddy6#$/
Bance
Postby Bance » Wed Jan 30, 2019 11:25 am
My guess is that the OP made the sketches in sketcherWB rather than using create sketch from within PD workbench.
There is absolutely nothing wrong with starting with an additive primitive by the way.
This model can be created entirely from additive primitives, and it would actually require less steps and leave a cleaner history.
Steve.
kisolre
Postby kisolre » Wed Jan 30, 2019 11:29 am
When creating a new sketch that will be used as a base for a feature in a body the body in question should be first set as active body (name should be BOLD - double click or rightclick/toggle active body) and then the sketch is created. You can see in Dependency graph that your sketches are outside the body:
Postby chrisb » Wed Jan 30, 2019 12:48 pm
All sketches created in Sketcher workbench are outside of bodies. All sketches created in PartDesign workbench are inside of a body.
Why this? I don't have issues with them. Dependency graph is simpler, and for me modifying radius or height is less steps than using a sketch.
NormandC
Postby NormandC » Thu Jan 31, 2019 5:17 am
Hi arcol,
arcol wrote:
Tue Jan 29, 2019 12:03 pm
It would be a water tank in the end:)
Who will fabricate it? If you have it done by a contractor, making it as a single PartDesign Body may be sufficient. But if you intend to build it yourself, then it would be better to treat each element as a separate body, so you can create separate drawings.
HarryGeier
Postby HarryGeier » Thu Jan 31, 2019 7:27 am
Well, we try to make the users understand to use references to sketches instead of faces and edges, these objects have no sketch underneath and thus are tempting to attach sketches to their faces. It´s a bit like mixing PD and PART . If you are experienced ynd have understood the inner works, you can surely do a lot of fragile and difficult things, but here we mostly deal with newcomers having a Problem.
Postby chrisb » Thu Jan 31, 2019 8:59 am
Good argument.
arcol
Postby arcol » Thu Jan 31, 2019 3:23 pm
Well, it is a 4m3 water tank (under the earth surface), but I'm not quite sure the guy well understood my requirements over the phone.
So I want to draw it.
I still have a couple of days to finish the drawing. The only requirement, that the tank fits my trailer, which is 1450mm wide,
thats why the 1450mm height requirement.
I have modelled the two pipes:), now I'm deep in techdraw tutorials,
my front/left/right views are all rotated in space, so each view looks like a perspective view.
The tank will be made out of 50mm thick PP sheets. I have no equipments to weld plastic that thick.
(the base sheet is that thick, I'm not sure about the sides and the top).
Thanks for the help everyone, I will post the finished drawing once I'm done.
herbk
Postby herbk » Thu Jan 31, 2019 3:42 pm
Hi Harry,
I don't see the advantage in that... May be you can explane it to me, - and may be it solves a bit of my prob with PD... :?
Gruß Herbert
